I recently picked up a 1938 version of the American Flyer 200, a HO New York Central 4-6-4. Looking at it closer however there are a few things different than all the other 1938 200s out there on the internet, and was hoping someone could tell me waht is going on, as I’m not a “serious” American Flyer collector.
The main things I noticed were the front truck was attached via a drawbar, not a screw through a slot in the center of the truck. Second, the tender chassis has a flat bottom, not a peaked one like others. Third, the tender trucks have brass plates under the axles, where as others only have brass pickup wipers. 4th, there is a lever protruding through the coal to manually cycle the reverse unit, and the hole looks to be cast into the shell, not drilled out. And fifth, there is no “made by A.C. Gilbert” cast into the tender deck behind the water hatch.
Some other miniscule things I noticed are the handrails in the loco are all the same height on the boiler, normally the last support on the firebox is higer up on the boiler side compared to the others. These two could absolutely be from a previous owner and probably are: a maroon cab roof, and a pipe across top of boiler at rear of smokebox.
Photos:
And reference photos as to what a normal one looks like from the Gilbert HO index and an old eBay listing:
