This is my completed American Flyer Trolley switch and platform. The platform is Department 56’. The switch is AF manual type with the track removed. I had to raise the platform additional 1/4’ inch above the Gargraves track for the Flyer Steam Engines could clear the sign attach to the roof.
You may notice I used a Lionel switch light cover. It has a light inside and activates when the trolley is powered up. The bumper is a cover off a toggle switch that is used to keep out moisture. I also added additional bumpers made from shrink tube (looks like rubber tires bumpers!
I epoxied the man in blue holding the sign to the slide switch. By moving him to any three positions on-off-on. He will turn the trolley on, off and turn the street light on when power is to the trolley switch.
If you look close at Rocky. That what I call him because is head is actually a small pebble or small rock. His right had was missing also. That is made out of the smallest shrink tube, with a cardboard sign added.
Yes, that Lionel trolley looks rather good in its new home running between my two outer loops of my American Flyer Cabinet-top layout. Oh Well, someone has to support Flyer/Lionel now days, no mater what gauge.
I will post more photos from this project later in the week f
Very nice. I recognized the Victorian Station Platform, I have the same item for my Christmas layout. I ran into the same issue you did with the roof overhanging the track, I believe it was originally designed for use with HO/OO scale trains. My solution was to cut the sides of the roof back so they were even with the platform.
This is the Trolley Switch I built from the American Flyer manual 722 track switch. This is the one with the longer switch housing that can be used manually with the throw lever or by using the electric controller. I needed this room to fit the 8 post On-Off-ON slide switch I found at Ace Hardware in town. The slide switch had to have 1/2" inch throw to control the lever arm length. It also had to be open ended to fit the round tube from the lever arm. I will get into this later in the post.
I went ahead and removed the track section along the same line as the manual lever on the track switch. I cut off the coil tube, and removed the wire. I shorten the lever arm and round tube from the lever arm.
The slide switch is mounted upside down, with the 8 electrical post pointing up. The slide is facing down and has to be shorten about 1/4" inch for base clearance.
Wiring as follows:
- Power from the transformer to red and black terminals on the switch. Wires from your stop sign signal on you layout to the green and yellow terminals on the switch.
