Amtrak #80 Carolinian hits tractor trailer.
Happened in north carolina. Will post more news but this first one has a cell phone video of the crash.
http://abc11.com/news/amtrak-train-slams-into-truck-in-halifax/550657/
http://www.wral.com/train-accident-reported-in-halifax-county/14502409/
https://twitter.com/6abc/status/574992895809306626
http://6abc.com/news/philadelphia-bound-amtrak-train-derails-in-nc/550717/
If this happened at Halifax, it is on CSX’s primary route between the NE and FL. There is no readily available way around it, although the old SAL line would have filled that role if it still existed. This will be a major disruption of all freight and passenger service on that line.
Google street view.
https://www.google.com/maps/@36.3307096,-77.5937943,62m/data=!3m1!1e3!5m1!1e4
Several thoughts.
  1. The distance from the tracks to the intersection is only about 40 feet. Intersections of this nature should be rebuilt further from RR tracks. Any TT or even 2 cars cannot clear. Since this a NC DOT road and train they should be able to fix this within a 1 - 3 year period.
  2. There are traffic lights at the intersection but not on the approach side.
  3. Load appears to be a manufactured home both longer and wider than a normal tractor trailer. May have also been taller than normal 13’6" ?
  4. In reference to #3 one report states load was trying to turn left but was having problems, Maybe trying to clear traffic lights or maybe went left of overhead RR signal. ?
  5. Stated was trying to turn for 15 (?) minutes with help of state trooper. That may be why the cell phone video is available.
  6. If #5 why didn’t trooper follow procedure and immediately notify CSX ?
  7. 40 injured
  8. Just what Amtrak doesn’t need another loco down for months.
  9. Heritage baggage car may have runits last revenue mile ?
The following link at about :05 shows a multi axel carrier that is often used for transporting manufactured homes. One report read says that whole rig was 164’ in length. If so quite a rig.
http://news.yahoo.com/amtrak-train-truck-collide-north-carolina-several-hurt-180638852.html
The reference to 15 minutes came from a bystander. We don’t know whether this is a wild estimate or a reliable figure. I also heard 30 minutes. Maybe it was only five. Maybe the call had been placed to CSX, but not enough time to get the message to the train. This possible delay in reporting the problem might be an important factor in the coming investigation. Or it might not be relevant at all. We don’t know at this point, so we ought to reserve judgment on that. It will surely come out in the investigation.
Additional report that says NC state patrol was escorting the load.
http://wtvr.com/2015/03/09/watch-terrifying-moment-when-amtrak-train-collides-into-tractor-trailer/
One of the first comments on a local article on this was “pipelines are safer than trains”. [^o)]
The news item cited by Blue Streak says a Highway Patrol officer claims there was about 4 minutes’ notice before the collision.
The Auto Train is starting late from both endpoints tonight, but it is running. Southbound Auto Train 53 left Lorton a little before 9 p.m. Presumably, the track will be open when that train gets to Halifax (normally about 3-1/2 hours, but hard to predict a time under the circumstances).
NC Trooper should have requested the railroad hold traffic for the safe passage of the load. Railroads honor such requests from local authorities. This incident has been caused by Trooper failing to protect the movement of the oversized load across the tracks.
I have to agree here, unfortunately this incident could have been very easily avoided, had the state trooper placed a phone call and simply confirmed it was safe to go across the tracks. Even just warning the RR that they MIGHT have to slow down, give them time to stop a train IF need be, to avoid the accident from occurring. Simple solution, overlooked by an local authority, possibly because they were not knowledgeable enough of the subject, or he/she just didn’t feel that it would have been an issue crossing safely, and were unfortunately incorrect on this. Did this state trooper have knowledge that he/she could call the RR and they would hold up, or at least slow down ahead of time, rail traffic nearby, before they even attempted to cross the tracks? It is a shame, that this accident occurred, and that many people got hurt, when it could, and should, have very easily been avoided. Would be more shameful though if it was due to simply not knowing these facts of a simple phone call would have avoided it. Another point, is some have said that the RR was notified about 4 minutes prior to the collision, was the Amtrak crew given the message? Yes, you would need, probably, more time to stop, but did they get the message in time to slow down? Even just slowed enough that they would not have derailed even though the collision would have still happened?
A secondary result of this incident has both sides of Auto Train leaving their origins nearly 4 hours late. With the lack of additional equipment, these trains will either have to ‘run themselves’ back On Time or Amtrak will have to ‘bite the bullet’ and cancel a trip from each origin to have the following day’s origination be On Time.
Yes, the Auto Trains left their points of origin about 4 - 5 hours late last night. If it had maintained normal running speed, the southbound train would have passed the site a little after midnight. However, in the actual event, that train did not pass Halifax until about 3 a.m. due to traffic backups. If that train maintains its current speed, it is expected to arrive at Sanford around 4 p.m. (a very loose estimate). That means arrival at Sanford approximately 7 hours late. Don’t expect that train to make up much, if any, time with a quick turnaround at Sanford. I understand the northbound Auto Train is doing better, but have no definite information on that.
Remember the old adage: “Late trains get later”.
Don’t I know it - they are out of their ‘normal’ operating slot and being late have lost their incentive to be operated On Time.
Read somewhere that a student engineer + trainer were on loco. That report seems subject to doubt but does anyone know ?
The trooper appears to have made a mistake. But it would be prudent to wait for the investigation to make a definitive conclusion.
But the cause may go deeper. Based on what I read, the oversize load was so large that the truck could not navigate the turn. It needed to back up and have another go at it. But traffic behind it had stacked up, and the truck could not back-up. Which raises a point!
Why are these huge, oversized loads permitted on the highways? Is the permitting of these huge loads a root or contributing cause of the accident?
In Texas I have seen oversize loads that take up more than a lane and a half on the Interstate. Getting around them is dicey. And when they are coming at you on a two lane road in west Texas, for example, many times you have to take to the shoulder to avoid being clobbered.
I suspect that the truckers that haul oversized loads have pressured the legislature in Texas, at least, to allow ever larger loads. I wonder whether it is true in other states?
I may have made an assumption not based on any fact so far.
Did the load come straight down the road that crosses CSX or did load come from the south road that is west of the CSX tracks ?
Noticed that this road also has very wide fillets for turning. That is not prevelant on other NC roads. There are several buildings down that road where the home might have been made.
Well must retract sveral statements and assumptions. Load was 16 feet wide and 16 feet tall ( no indication whether this was loaded height ).
  1. Load was some kind of electrical equipment.
  2. Load and tractor trailer weighed in at 258,000 pounds. That weight certainly did not do the damage it could have. Suspect loco frame may be bent ? load listed at 164 feet but no indication if that was just the unit or the total length of the rig.
  3. Load was on 13 axles. or approximately 20,000 # per axle. That is usually more weight than the 16,000 per axle allowed on regular tractor trailers that have the apparent axle spacing…
  4. Unit built in Clayton, NC approximately 20 miles SE of Raleigh.
  5. Unit was going to New Jersey.
http://www.msn.com/en-us/news/us/college-student-in-recent-car-wreck-survives-train-crash/ar-AA9AsnO#page=1
The insurance claims are going to be many and very high amounts.
The above article stated trooper must be in contact with RR dispatcher whenever crossing any RR.
16 foot height might indicate the overhead crossing signals might have fouled the load ?
and for clincher
http://www.wncn.com/story/28359720/highway-patrol-never-notified-csx-prior-to-amtrak-collision
I can’t get the link cited by Dutchrailnut. An item from the Charlottesville Daily Progress and the Waynesboro News Virginian says the load was too big for the Interstate Highways. The byline was Michael Biesecker and Jonathan Drew. It seems to have a fairly balanced coverage. It says Lt. Jeff Gordon of the NC Highway Patrol claims notifying the RR was not the responsibility of the trooper, implying it was all up to the driver.
Wasn’t modular construction considered? Or fabrication on-site in New Jersey?
Boy there are so many articles on this crash that its impossible to cite them all.
A thought. FWHA and FRA should require that if any oversize load that might not be able to clear a RR crossing in 15 secods then the RR must be notified before crossing the RR crossing. A load 154 feet long going 5 MPH ( ~ 7 feet / second ) would take 21 seconds to clear. + add in rail width and crossing gate setback 24 seconds.
Used 15 seconds due to most crossings have a 25 second warning before train arrival.
The turn involved in this crash IMHO automatically makes one think that even a load 80 feet long cannot clear in 15 seconds.
Does anyone think that the NC state patrol is CYA ?
The problem of oversize loads fouling RR crossings needs addressing nationally. As well extra wide or extra tall loads will take longer to go thru RR crossings if they have to maneuver around utility lines and / or RR crossing gates.
