So you believe that the owners of the ethanol company intentionally went into bankrupcy because they hate railroads???
The Ethanol industry has been foundering since gasoline prices dropped off ( the various gas/ehtnol blends are not price competitive in the current market). AFAIK, every single large ethanol plant in the country uses rail service, trucking out that much bulk product would be very expensive compared to using tank cars…
More than likely, the bankruptsy had nothing to do with rail service. I’m sure they had planned to have rail service from the start…they just didn’t plan on going bankrupt.
You’re a bright kid, think this through. If your local paper said that the plant, if built, would ship by rail, that is because it was designed that way; therefore the ethanol company wanted to be a railroad customer…
If you’re disappointed due to the loss of a potential railfanning location think of all the people who either lost their jobs when the company went bankrupt or who won’t be able to get jobs building or working the plant…
A combination of gas prices, and corn prices last June. Going from $4 to $8 per bushel maked a large hole in the balance sheet, something price cannot overcome (unless we see $5 a gallon gasoline).
First off, if a plant has to take corn in by rail, it might not be very profitable. Corn, as it was said earlier, is the biggest expense of an ethanol plant, adding transport to the price narrows the margins. Now a days, to disgusting levels.
Second, gasoline (denaturant) is for the most part not railed in, but trucked from the local pipeline or refinery. I have not seen tanks of gas for a couple of years now.
Ken, this isn’t intended to be adversarial on my part. I just write down what’s the viewpoint of some of us in the railroad industry.
The railroad industry is not 100% consistent between carriers (and who would want it to be) and not 100% consistent at any carrier for all industry track designs and service plans at all times in all places. There’s a number of plants approved by a carrier one day that might not be the nex
I’ve been putting off answering this because it’s a long, long answer. To start with, there are hump yards, flat-switch yards, intermodal yards, autorack yards, industry yards, marshaling yards, train servicing yards – and that’s just the broad categories.
An unswitchable yard I categorize as any yard that requires significantly more labor, track, locomotives, maintenance, and risk to lives and property to accomplish the same production as another yard. It doesn’t mean it can’t be switched, it means it can’t be switched efficiently.
Some general guidelines are:
Straight tracks. Curved tracks block vision. Blocked vision means it’s easier to run into things and run over people.
Flat tracks. Cars run away on grades; it takes a whole lot more labor and lot more risk if skates and handbrakes have to be used.
Simple ladders. Any time a man has to cross over a track to throw a switch, that’s a man at risk of being run over by a rolling car or a moving cut. If internal crossovers have to be used, consider powering them up.
Decent-sized turnouts, softened curves. Small-number turnouts and tight curves mean high maintenance costs and increased risk for derailments.
Logical layout. Complex layouts confuse people. Employee turnover means a lot of time is spent training people on where things are and how it works instead of on developing safe and efficient work habits.
Efficient connections to the main track. This doesn’t necessarily mean that the main track requires an expensive, fancy
And this makes an EXCELLENT Argument for shipping Ethanol by TRUCK. Seldom(as in has Never Happened) do 18 Tank Trucks all crash at the same time, and have 14 of them burn uncontrollably.
The point here is that whichever method of transport is used, there are risks involved. Also, whichever method of transport is used, there was a REASON for selecting that method. There are situations where truck transport is the best or only option, and times when rail transport is the best, but rarely only option.
Perhaps. Of course the explosion and fire of 14 carloads of ethanol, about 55 truckloads, resulted in one fatality at a grade crossing and damage to private railroad property at a smaller cost to taxpayers. The truck accident also caused a fatality and extensive damage to a public highway. According to published reports guardrails on an overpass above the fire melted and structural steel was deformed possibly requiring replacement of the overpass. Good luck getting that covered under the trucker’s insurance…
Thanks RWM for taking the time and effort to lay it all out for us. I’ll have to read it again and probably a third time to soak it all in. It is pretty easy to stand at a distance and criticize things one doesn’t really understand. People do it all the time. Here you have opened our eyes to some of the factors that go into designing a yard. It is most interesting. Thanks again.
Best of what kind? Hump? Flat-switch? IMX? They’re very different animals.
Best on what basis?
Not sure I can answer this because the purpose and need of every yard is quite different from every other. Conceivably you could say “OK, pick the yard that best matches its purpose and need,” but even that is not a valid comparison because some of the purpose and need sets can be very difficult for any yard to address satisfactorily. And the geographic constraints of every site are really different, too.
Another way of looking at this is that I could take a given Class 1, and say “such and such yard is a pretty good one, and this other one is a dog.” Any most of the people at the Class 1 would agree with me. But that doesn’t mean that the dog can be trained to heel, it might be a poor yard for reasons that no one could or can control.
Welland yard on CPRail (Hewitt) . Flat land with a bowl shaped so they don’t need to kick hard and the cars role well. It’s symetrical, straight , weilded rail no sharp curves,long leads, no public crossings and good viability. Theoreticaly hand brakes are not heeded but required as per blanket rules for all yards. Built and payed for by the government during a relocation when the Welland cannal was expanded cutting off the old curved Welland yard.
