My switch track thread was kind of lame but I still think technology has it in its means.
Where the heck is modern model railroad locomotive technology these days?
Did they miss out on something after they charged tools with lithium batteries not taking it everywhere they could?
The tender behind the locomotive could be a lithium battery to power the locomotive to achieve a no longer need for wiring a layout. And Wireless just like the RC planes in the sky.
Need another lithium battery in case ones getting low, …Put it in the Box car behind the tender and charge them at night just like my Milwaukee tools.
What’s going on with these modern-day engineers today Guys? Did they miss something while they packed their bologna sandwich in their lunch box?
Some of them are likely huddled discussing what happens if you short a modern lithium-ion battery of substantial capacity that does not have its own distributed internal resistance. Some others are concerned with what happens if one of these batteries is inadvertently punctured or overheats to the point leakage of atmospheric moisture might start.
Others comfortably point out that just such an arrangement is likely a hallmark of emerging dead-rail approaches … yes, we need a more interesting marketing-style name for it, the sort of thing a ‘woke’ plain-bearing manufacturer might develop to compete with Timken…
As noted here, the ability to float- or intermittently-charge the Li-ion battery from some combination of wayside and track power is significant. And should be designed into any nominal ‘dead-rail’ system architecture, to a proper standard.
This topic has been discussed a number of times before. For me it’s just one more thing to maintain and go wrong and an additional expense when they have to be replaced - especially if you have a number of locomotives.
I worked in two-way radio communications for Public Safety for 50 years and batteries were my worst nightmare. The only way batteries work correctly is with proper maintenance and proper maintenance requires perfect charging. How many times have you picked up a battery driven device and it didn’t work because the battery was either dead or close to it? Before I retired 50% of one clerks time was for the maintenance of 1500 batteries.
I for one wouldn’t even attempt at running my trains from batteries. I do use rechargeable batteries to power all kinds of goodies for backup power fail. But even those batteries require a lot of managed maintenance, it only takes one error for them to not perform their duty and leave you in the dark!
The new Lithium batteries are great but still require time devoted to keep them working properly, the first time you let your guard down (maintenance) you will be sorry.
I have a strict maintenance schedule for all my rechargeable batteries and so far I’ve done OK. All my passenger cars, coaches and cabooses have battery backup lighting (flicker free lighting with coin cells trough 18650 Cells) and are kept charged by onboard chargers. Once a month I swap out all the batteries and run them through a battery conditioner/analyzer to make sure the capacity is up to spec.
As for RC flight I would like to know how many planes have bit the dust because the batteries failed or didn’t last as long as expected.
Batteries are only as good as the person doing the maintenance.
Ramblings from an 83 yr old guy that worked with batteries for 50 yrs.
This is exactly why I prefer modular lighting that uses capacitors. Still flicker-free but no need to take a car apart to access/test/change batteries.
I’m currently working (sorta) on a dead rail Mantua Pacific (now a Hudson) for a friend. I was surprised by his interest in it, as he is stridently opposed to DCC, and this install includes a decoder and wireless throttle, along with the lithium battery. If I’m successful with this, he won’t even have to take it off the track for re-charging…just plug it in and flip a switch on the tender’s deck.
Personally, I don’t see the point of this, given the outlay of cash necessary, although subsequent locos wouldn’t need another charger or throttle.
Even though I really don’t like batteries the thing I do like is the ability to leave my passenger trains lighting on when I’m operating in DC mode. I can park a train at the passenger station for hours with the rail power off with full lighting.
I have the battery (AA size 14500 4 volt 1200mah) and charger in the baggage cars for both my streamline and heavy weight trains. The LED lit cars are daisy chained from the baggage cars.
My old timer coaches and cabooses use a LIR2032 coin cell(4 volt 40mah). I made it to where the shells come off supper easy with micro connectors mounted to the shells and floors, no messy wires.
Li-po batteries can take many charge cycles, I don’t thinkt here is a problem there. Space, is the m,main issue, as usual. Outside of steam locos that come with large tenders (ironically, the ones that LEAST need keep alive technology, at least if they are wired to pick up both sides of the loco as well as both sides of the tender), there just isn’t room for allt he stuff. On many diesels, there’s just enough room for the DCC decoder, and a speaker. OK, repalce the DCC decoder with a direct radio control receiver. Now, where do you put the batteries? Using a car behind is absolutely, 100% not acceptable for anyone who wants to do anything beyond simply running the trains around - even the most casual of operations, requiring a specific car to be coupled to the loco is just not practical.
For larger scales - battery operation has been a thing for many years now. Especially G scale, since in an outdoor environment it can be really difficult to keep the track clean for through the rails electrical pickup. LGB and other locos have had sockets on the back to connect battery power (or link two of the smaller locos for a better wheel pickup area) for a long time now. Several manufacturers have offered the radio control systems.
For it to work, it need to fit completely in a loco. The box car tagging along just on’t do. That’s been done for non-scale toys, battery goes in a car, it all hoosk together and gets set on some plastic track, and off it goes. But it’s too toy like. A loco needs to be able to run by itself to the service track. To go out to the ayrd and couple to its train. To uncouple fromt he traina nd run around to set out a car. None of that would realistically have the same box car couple to the loco the whole time. Needing a car coupled on turns scale model railroading into just another toy train.
Even if you took all the metal weight out of a typical powered HO loco - there’s not much room for a battery. Certainly not an off the shelf one which would make such an arrangement affordable. Custom packs designed to fit in specific spaces would NOT be cheap. ANd like you need different size decoders and speakers to fit different model locos, you’d need multiple custom battery packs, and thus so much for volume keeping the cost down. Plus with no weight and the space filled with li-ion battery - the loco would have no pulling power. And don’t even think about going back to the days of rubber traction tires. We have thankfully left that behind in the 70’s where it belongs, for the most part.
It’s simply still not practical in HO and smaller, other than steam where you have all that room in the tender for a nice size battery pack. Case in point, I have a small drone that fits int he palm of my hand. the 1S li-ion battery pack that goes in it, which makes it fly for 10-15 minutes tops, is still too big to fit in most HO diesels. OK, it has 4 motors, so maybe the same size pack would run the HO loco 4x as long, up to 60 minutes on a charge. Maybe that’s enough - but don’t forget the part where it won’t fit in most diesels. In a steam loco tender? Easily. You could go bigger, for even longer run time, in a steam loco tender. There still is not a p
Well I certainly hope model train manufacturers do not go the tool route where they each have their own battery not compatible with anyone elses trains.
As mentioned above, standards are the key to widespread use.
But the benefits have to outweigh the drawbacks and I don’t think we’re there yet. The benefits are not wiring the track and not having to clean the track. The drawbacks are the extra cost, having to recharge the battery, having to maintain/replace batteries, and limited run time.
I did notice the batteries for my Milwaukee Tools went from $100 to $150 a piece while I was at Home Depot the other day.
It would definitely only become an alternative for the rich. The only rich I know of playing with their trains is Rod Stewart. I’m very sure there is many more though[swg]
LIONS do not like Bat Trees. The droppings are a big mess.
Besides him has never had good luck with rechargables.
Although I do have seventy pounts of recharageables here in my office waiting to be switched out on our UPS devices. Have to send the boy around to take new ynits up and to bring old units dow for re-bat treeing.
