While laying homabed Ive noticed that some of the 32" pieces bend rather stiffly (18" radius) almost to the point of breaking. I should mention that Iv
e snapped several pieces and it was not due to my bending them in the wrong direction. Richard states that homabed can be used on 18" radii. What I would like to know is do any of you modify the machined kerfs Eg. open them up by using a razor saw or a utility knife blade that will make the kerfs wider than they come from the mill so as to get more bend space ? Or perhaps you do something else to make it easier to bend. Thanks
I have never ‘formed’ them down to 18" radius, but have done a lot of 22" radius curves. The curved stuff has 45 degree ‘kerfs’ in it. I draw out the center line of the curve and lay the outside section of the curve first. Be gentle! I use wood glue(Titebond) and tack down the curve with wire brads. I start at one end and work down the track. After the glue is dry, I pull the wire brads and ‘finish sand’ the roadbed. BTW, I used the 45 degree bevel(the 60 degree bevel was not available at the time). I even ‘made’ curvable roadbed out of straight material when I ran low one time. You can take a saber saw to them and make the kerfs longer/wider if needed.
Jim
