Another LokSound V5 trick, coupling
Here is another trick for LokSound V5 decoders that may be of some interest.
I always run my trains with momentum, both for the realism and for the sheer sport of it. When coupling, however, momentum is a bit of a problem as the loco wants to continue pushing for awhile after the collision. I program my V5 decoders to make this a more realistic event.
I guess all of these decoders’ sound files come with a “coupler sound” mapped to a function. It just plays a sound. I add 2 things to the “Logical functions” column of the coupler sound function. I add “Acceleration” and “Brake n” where n is 1, 2 or 3.
The acceleration logical function immediately kills all accel/decel effects. The effect of this is that the loco stops immediately but only if the throttle has been set to zero.
The brake 1, 2 or 3 logical applies the selected (preprogrammed) brake value. Adding the brake logical is not necessary if the operator kills the throttle just before the couple but I find that clumsy. If the brake logical is added and the selected brake has been configured to set a maximum speed of zero when that brake is applied, then when the coupler function button is pushed the throttle sound will go to idle, the coupler sound will play and the loco will stop almost immediately, like the prototype. For even more realism, if the Coast function is activated some distance before the couple point, then the throttle sound will go to idle and the loco will drift realistically. Then when the coupler button is pushed the couple sound plays and the loco stops. If the brake logical is added, then coupling is just a matter of pushing one (or two for more realism) function buttons rather than fiddling with the throttle. It’s mighty realistic.
Three CVs control brake aggressiveness: 179, 180 and 181 for brake 1, 2 and 3 respectively. Three CVs control the maximum speed that can be run when the brake is applied: 182, 183 and 184 for brake 1, 2 and 3 respect
