Q2 compatible firmware (which has downloadable sounds) for the older Q1a factory sound decoders. So owners of older QSI decoders can get the newer and better sounds in their locos without buying a whole new sound chip. Another reason to like QSI and their programmable design.
No, this is a firmware upgrade that allows you to used the Revolution sound files. You have to already have the Q1a chip upgrade. And a Quantum Programmer to laod the new firmware and sounds.
Wish it also improved the BEMF of the older Q1s, too. The Q2 decoder in my Atlas HH600 is just terrific. [Y] As good as - if not better than - my Loksound decoders.
That’s almost certainly a NO, hence the indications that there ARE a few limitations using the Q2 firmware with the Q1A chips - less storgae space means picking one whistle/horn and loading it, vs having a dozen available to pick between on the fly. Unless you’re modelign an excusrion loco where various groups will often bring a different horn/whistle to be attached for a specific trip, this shouldn’t be a problem.
