Another question about Peco Code 55 Track
I noticed that Peco does not sell pre-wired terminal rail joiners. Will Atlas Code 80 terminal joiners fit the Peco track?
Not very well. I tried using some of the Atlas terminal joiners, and they weren’t very reliable. I ended up having t solder them, so I decided just to solder the wire right to the rail and use the Peco rail joiners instead.
Scott
Peco part number PL-82.
Just make them yourself, MUCH cheaper - solder wires to the normal rail joiners. Make up a bunch at a time, so you have them ready. (if you are squeamish about soldering to the track)
Peco makes them, I believe they are universal. it’s 6 to a pack of I’m remembering this properly.
Yup, turns out Peco does make them. For some reason the mail-order firm i usually deal with doesn’t seem to list them.
