As some of you know I been after a Santa Fe War Bonnet C44 W9 for a while. Well I won one on E-stuipd. Was listed as a MRC that I now know should have been a Athearn.
Not sure what the heck it is at this point. Body looks good, has ditch lights but not a Athearn. Seems it was something that was kitbassed (sorry about the spelling) and many driffrent parts where use. Trucks are Athearn FP-45’s, motor is some kind of Proto (for get the name I was told when I first posted about the engine). No fly wheels, one drive shaft is Athearn, other is rubber tubbing.
When I bought it it was listed as “runs but need’s cleaning”, it was a sold by a MRR club. I have cleaned, replaced the trucks with fresh FP-45’s truck and it run’s! But it sure makes a racket, makes a Pan Cake motor LL seem quite!\
Seller, that is sending me my money back, so they are good guys. But I hate to use it as a dummy sitting on a spur.
Does anyone want to play with it? I will pay shipping both ways plus cost of parts with in reason.
Darth Santa Fe, I know you have great skills and a weak spot for the War Bonnet’s like my self. Want to play with the mess? \
If you want to run it out to the Train Haus in Warrenton MO, I would be happy to see if I can get it going for you. b0b buesking@ktis.net (573) 456-0117
Is that motor soldered to the frame? If so, resonance is probably a big contributor to your noise. I would replace the motor with a longer one and isolate it from the frame with silicone glue, and then set up equal balanced drivelines. You do not absolutely have to have flywheels but a double flywheel equipped motor may be a better fit. Anytime you have anything unequal rotationally balanced wise in the driveline it is going to vibrate, and that equals noise. Because of costs, our motors will hardly ever be perfectly balanced, so isolate them from the frame/body with some type of elastomer. Rubber tubing ‘U’ joints actually work pretty well, IF there is not much of an angle and it is goog quality thin walled tubing with the hole centered in it. NWSL motors, joints, and shafts are pretty good in my experience.
That looks to me like something a little kid put together. I may be wrong but this appears to be an old Railpower frame and Atherarn trucks with a Mashima motor. The Mashima motor is one of the best motors to re-power with. Why it has no flywheels only the “builder”, and I use that term loosely, knows for sure. It also appears the shafts have some type of brass tubing used to increase the diameter of the shafts. This was probably done due to the trucks, which are 2.4mm diameter and the Mashima motor, which has a 2.0mm diameter. The long tubing on the one shaft is not good. I have seen tubing work well when used in applications where the shafts are close together and do not pivot, such as steam engines. In your case you need to use flywheels and drive shafts. What you need to fix this mess is to use the A-Line flywheels and drive shafts. The flywheels will fit your 2.0mm shaft. The drive shafts will couple your 2.4mm trucks to the flywheels.
This engine is a “beater” - I’d suggest your efforts and money are better spent on scrapping it. You can spend all kinds of money to get it running right, and you still would have an orphan.
First off, that’s a C41-8W not a C44-9W. The brakewheel on Dash-9s are located in the center of the radiator not the back, they’re longer too. If you want a Dash-9 in the Warbonnet here’s what I’d do: Buy an Athearn Dash-9, repaint it if needed. Make sure you buy one with high-numberboards (sometimes called eyebrow boards) as are found on all Santa Fe GE widecabs. I’ve seen them being sold used for around $40 at local shows and such. Now if you want to keep the one you have, well that’s going to take a LOT of work. Pretty much the whole thing is going to have to be rebuilt from the ground up, the shell will need to be redetailed and repainted. My bet is that this was a custom build by a modeler before the Dash-8 was avalible in plastic. It doesn’t have the right cab and the motor is not isolated. Repowering with an A-Line kit is a good idea but you’re probably still better off just buying something else mate. Cheers! ~METRO
Have to agree. You like the look of Warbonnets and someone else did too, so they decided to build a unit, perhaps not doing the best job of it. You have a shell and a frame and have to decide if they are worth building an engine around. From what I’ve read, you’ve already replaced the trucks and now are told to replace the drivetrain. Basically build an engine.
I believe that the problem with this loco is fairly simple to fix. From studying the pictures, I believe the problem is the tubing “whipping” as it turns. In other words, the middle of the tubing deforms due to centrifugal force. A simple experiment to see if it is the tubing doing this and slapping against the wiring is to simply cut the tubing into two shorter pieces and use some kind of “shaft” to connect between the cut ends. The ends only need to stick out between 1/4 to 1/2 inch from the motor and the gear tower. Insert a solid piece of brass, a piece of code 100 rail, even a styrene rod will work, between the cut ends. If this doesn’t eliminate or greatly reduce the noise, I’ll be surprised.
Mashimas are extremely quiet and replacing Athearn parts between the motor and gear tower with tubing and solid shafts has made many an Athearn extremely quiet.
Are you sure this engine isn’t a “parts bin special?” It looks like something that was thrown together simply to use up spare parts. I’ve seen quite a few of those (locally) recently. I’d like to smack whoever is putting cabs from F units onto F45/FP45 shells…and trying to pass them off as E units.
I think the motor is an early Mashima. It looks similar to the one in my GSB SD40, but I could be wrong.
A lot of the noise may be coming from the worms, if you used old ones. My uncle loaned me his Athearn FP45, which he put a Sagami motor in, and it was very noisy when I got it. I replaced the front worm with a good one, and now it’s nice and quiet.[:D]
I don’t think I’d be able to afford another engine right now, since work’s been a little slow lately. I’m sure someone else might still want it though, so maybe you could sell it on eBay as an “HO DASH 8 for parts,” and list a few certain things about it, like the new trucks. I’m sure it would make some money for you, possibly to put toward a new DASH 9.[:D]
Orphan??? Dang Bob, I figured you’d put it a lot more bluntly than that. All I can say is…dam, what a piece. Sorry, Ken. …I hope you left them crummy feedback, by the way. Ken, I have a suggestion. There are LOTS of experienced modelers here. ASK before you buy. Information is free. Finding out the hard way is not.
Okay here’s the thing… Someone made a big boo boo!! If that locomotive is supposed to be a C44-9W, I’m afraid your in trouble. The trucks under that locomotive are suppose to be HI-AD trucks ( standing for “High adhesion” trucks) The trucks under your locomotive are early style EMD trucks. Something that you will see under an SD40-2. If I were you I would go out and purchase a set of Dash 9 trucks from Kato. Plus, the frame your locomotive is sitting on is also an Athearn frame along with your trucks. The reason your hearing all the noise is probably whats going on inside those old Athearn trucks. The gears in those things might be older than you. The motor would also need to be changed. That thing looks like it went through an explosion. That might also be the source of some of your noise. I have a friend that has a better motor and we could replace that with it.
What I’m guessing is that someone took the original shell off the frame and replaced it with some other shell. Because the Shell you have on now is definately not Athearn. Usually Athearn has a bit higher detail than that, even though they’re not the best company in the world.
I am sorry to break the news to you but what you have is probably not a dash 9. The shell on that frame looks to be a Dash 8. The predessor to the Dash 9.
James
E-mail me if you want send that locomotive my way. I can help it a little.
Darth, you got it wrong, I don’t want you to buy it. If you have the time and with skills you have I wondering if you might want to try to fix it for me.
I will answer the questions the best I can remember. (I miss the old site)
Motor is glued in, looks like silcone or some other goo.
Worm gears where repleced with the trucks.
I all so thought the racket was from the rubber shaft and it is 2 pices. Pulled it and still a racket.
As far as the Athearn, well I would like one but not happy with the power need. I wish PK made one.
So it not a Dash 9, not a big deal to me at this point! I know nothing and half of my F-7’s may be F-3’s. That is the great thing about being new, I know nothing. All I know is a Dash 9 has a door in the nose and a big over hanging radatior in the rear.
Body has no mounting points either, just sit’s on the chassie, couple box when screw down is all the holds it.
I will try posting some movies of it in the next posting. Maybe some will no where the sounds come from.
Last one is the motor running with no shafts. Some of the hum is from the stereo. I have a nasty Audiophile system and the two Mono Blocked Amps at 600 watts a side have a fan to cool the heat sinks. I turned the volume down but need not shut down the stereo.
In that case, I guess I could give fixing it a try.[:)] If you e-mail me, I’ll tell you where to ship it to. My e-mail will be in the “interests” line in my profile temporarily, so you’ll know what my e-mail is (I’ll be taking it back out after we’ve worked everything out).[:)] (click my screen name to see my profile)
