I recently bought a modern ZW second hand. The handles were loose and tender to slip alot. When I opened the top cover, I found that the gears that the handles were linked to were jumping and skipping if you put too much pressure on the handle.
I believe this was a early production unit that had this problem and that Lionel had a kit to fix this. Does any one know anything about this retrofit?
Thanks. I will have to track down a copy of CCT. Does the fix involve adding a metal bracket to gear assembly?
I also got a reply from Lionel website: “They don’t a have a kit. …sent it to your local service center to fix it.” If they don’t have a kit, how is a service center suppose to fix it? Oh well…
Thank you Boxcar Bill for the Lionel part number. I have ordered them and look forward to getting it. Still have to track down the Feb CTT issue. Thanks again
