well i got all my stuff that i needed track,train t1 4444 and my transformer mth 400 watt, i had trouble with cw 80 cause it would not run the t1 now since i got the mth 400 watt do i realy go advance on a layout that i realy made small. me and my daughter are wondering… do we need a remote for something so advance cause the t1 got all the toys, sound rail fxs,smoke how do i adjust it for more smoke and chugging i think 12-15 steps of it and it can do O31. what can i do on curved treasles down a hill or up a hill. i need some action to the layout,is it a risk taker.
Hi CHAD,
Glad you made the transition to the bigger transformer. About getting into so many different things. Slow down and run your train on the layout you have. If you like all the clearences that is needed with your T1 then you can start to think about different accessories and what to get, and where to put it. This is my third layout and have found out that NOT rushing into the layout and watching the train run, desiffers what I will do with accessories. I run lots of different trains and want to make some sound decisions on how to operate them. So for now run the train have fun with your daughter, and both of you can decide what would look best for the layout. As far as remote control, its the best. If you can afford it go with it. It gives you all the action right in the palm of your hand. Good luck.
laz57
If your T-1 is an MTH engine the CW-80 won’t work with it, NOT on the list of compatible transformers by MTH. Personally I would rather have a 100 watt transformer than an 80 watt.
Most of your larger engines, steam and diesel need larger curves or they de-rail!!
Curved trestles down a hill is just an accident waiting to happen in my opion, especially with a T-1 steam engine because of the weight. Use a smaller 2-4-2 steam engine with magna-traction for a trestle set.
Lee F.
