Just picked up a alco rs1 (Minneapolis st Louis) and not sure how to go about weathering it. It’s been transplanted to the pacific northwest part of the country to be a yard/industry switcher so I’m figuring it needs to be extremely dirty/rough looking
This is an RSC-3, a variant with 6 axles to spread the weight for use on less robust rail lines.
This is a GP-9, but the weathering could be similar:
Neither of these is heavily weathered. You can see rust and dirt, but they don’t look like they’re falling apart, and, in general, they shouldn’t.
For both of these, I removed the shells and sideframes from the wheelsets, and taped over windows and headlights with blue painters’ tape. I gave the shells and sideframes a layer of Dull-Coat from a spray can, and then weathered them with AIM powders. I used a second layer of Dull-Coat to seal the powder in.
Here’s one on the Maryland Midland at Union Bridge, MD from 1986. Sun-faded on the top and greasy at the base of the entire engine compartment:
Hope this helps.
Bill
Here’s a photo of my heavily kitbashed, 1/24th scale narrow gauge RS3:
When I decided to do this project I didn’t know anything about RS3s, so I did a lot of research online prior to building and painting it. Google Image search was extremely helpful. I found a ton of photos showing RS3s with various degrees of weathering. Some of the most heavily weathered locos I saw were on the Lake Superior & Ishpeming RR (LS&I). Here are a couple good ones:
http://www.rrpicturearchives.net/showPicture.aspx?id=1607486
http://www.rrpicturearchives.net/showPicture.aspx?id=1607485
Another excellent reference resource is www.railpictures.net. You can select the type of loco or rolling stock you are looking for, select the railroad, etc. Here’s another LS&I loco:
http://www.railpictures.net/viewphoto.php?id=422807&nseq=14
BTW, my RS-3 started out as a 1/29th scale loco from Aristocraft. I model narrow gauge in 1/24th, so I needed to rebuild it to a larger scale. I built an entirely new cab (with interior details), made the hoods taller, made the stack larger, added a bell, widened the deck, built new handrails, new pilot, etc. I also replaced many of the molded details with homemade details, and extensively reworked the truck side frames. In the photo above, I had not yet installed the front coupler.
Thanks guys! I’m really new tO the hobby and these forums have been extremely helpful
Any reason you picked up a Minny Lou for that purpose?
Was the only scheme I found on a RS1 (and got a great deal on it)
Well and it’s a pretty unique (IMHO of course) paint scheme.
Yes the Minnie Lou was famous for having a paint scheme of the month (sort of like the Rock Island). Which one do you have? I believe Atlas has produced a yellow & grey version and ared & white one.
If I was starting over again today and choosing a prototype I would seriously consider doing the Peoria Gateway.
Have sent PM.
Mine is the gray/green version
How about pics of real M&StL RS-1’s?
http://www.rrpicturearchives.net/locoList.aspx?id=MSTL&mid=237
This one here is pretty grimy: http://www.rrpicturearchives.net/showPicture.aspx?id=275227
Paul A. Cutler III
