Any Plans/Schematics of USSR State Railway's P36 Class?
As you can probably guess by my username and the topic of this thread, I am an avid fan of the USSR/Russian State Railway, paticularly its steam locomotives, and I would like to build a layout on this topic; thus do you have any plans or blueprints of their steam locomotives?
Pleas contribute with following posts.
The Soviet Union was very secretive about nearly everything. I doubt you will find anyone with drawings. Contacting the Russian department of transportation may yield results or it could lead to a visit from homeland security.
https://en.wikipedia.org/wiki/Russian_locomotive_class_P36#/media/File:Parovoz_P36_razmeri.jpg
There are numerous railroad and transportations museums in Russia. They may have a web site that would give contact information. The Hermitage art museum in St Petersburg does. I would think that even despite their political differences with us, they would still be eager to share their historical ‘treasures’ with us and the rest of the world. Might be worth a try.
Mark H
There have been numerous books on Russian railroads published mostly in the UK. You can find them pretty cheaply on Amazon used books, for instance http://www.amazon.com/Russian-Steam-Locomotives-Murton-Fleming/dp/0715354957
At various times, there have been Russian prototype models in HO, offered either by German or Russian makers. Some Chinese equipment from Bachmann China is also similar.
Our well informed and hard working New Zealander has it right.
The diagram on English Wikipedia is that which appears in most references, including the standard book “Russian and Soviet Locomotives” by V.A. Rakov (who has produced a number of such books, some relatively recently)
The standard types are described on English Wikipedia, which can be reached from Ja Bear’s link above. If you have a browser with translation capabilities, there is also a link to Russian Wikipedia which has much more detailed (and very interesting) articles on every Russian steam locomotive type imaginable.
Although I’ve lost the link, there is on Russian Wikipedia a complete official steam locomotive diagram book from the early 1930s, which includes certain foreign designs considered important by the Soviet authorities, including the UP 4-12-2 and SP 4-10-2 and the Austrian type 214 2-8-4 among others.
There is definitely no shortage of information on the web on Russian steam locomotives.
I know of no models of Russian steam locomotives currently available in any gauge. There was an HO model of a type Ov 0-8-0 available in late Soviet days I believe.
The best starting point to get an HO layout under way would be to buy a Chinese Bachmann type QJ 2-10-2. This uses the basic chassis of the last Soviet freight locomotive the type LV 2-10-2, but it was stretched in length to take the larger boiler of the type P34 2-6-6-2 (which was a one off prototype).
If you take the QJ and remove the smoke deflectors, you would have a locomotive tha
You’re [#welcome]
For the underframe I think you could get away with using a modified Bachman GS4 assembly, though the QJ does seem a bit expensive for a model to cut up on (I myself would recomed scratchbuilding of the shell.
I’ve seen that drawing before, but thanks anyway because I couldn’t find it at its source.
P.S. What are the measurements on that diagram? It looks like milimeteres, but is hard to tell…
All the Russian locomotive diagrams are dimensioned in millimetres.
The QJ is a very nice model and runs well if a little slowly. It does make a good stand in for the LV as it is, just renumbered.
Check out the respective drawings at:
https://ru.wikipedia.org/wiki/ЛВ
and
https://commons.wikimedia.org/wiki/File:QJ_drawingside.jpg?uselang=ru
The GS-4 has 80 inch wheels and although I think the Bachmann version has slightly undersize wheels they might be a bit big for 72 inches on the P36.
If you could remove the skyline casing from a plastic GS-4 and substitute the taller and narrower casing on the P36 and alter the valences to suit you’d have an oversize but good looking P36. You might still want to use the QJ tender or scratchbuild one a bit bigger to match the locomotive.
M636C
