anyone build\building either of these plans?
Nik & I are looking at a couple of ideas for plans, but other than the plans here at MRR, we can’t seem to find any examples on the internet.
We’re considering a modified version of the “Naugatuck Valley” from the “Building a model railroad step by step” book, or the “Housatonic Valley” from the August 2008 MRR magazine.
We’re looking for building and operating experiences and opinions, as well as images- trying to get ideas.
We’re still in the phase of enjoying watching the trains just go round (Nik is 9, dad thinks it’s cathartic after work, esp with a tall scotch). However, we’ve been talking about how we might play with trains in a couple of years- trying to introduce some ideas of what trains do in real life.
Anyway, as always, help, advice and opinions are appreciated.
Other people’s opinions may differ and probably do,but I’ll let you know about my own experience.In my opinion,you have reached the toughest part of your layout creation,planning wise I mean,construction being your next challenge.You have spent some time negotiating with the master of the premisces (as I did) and have had a choice to make as to wich room (I didn’t have that choice) to use.Then you have decided wich one will suit you best and now are confronted with your hardest decision…deciding what the layout will be.Since there are two of you,goals and ideas may differ a lot so you’ll have to negotiate again,between you this time,as to what both of you would like the layout to be.
What features do you wish to have?Point to point operations?A switching layout?Continuous running?A single or more mailines?Some of all?You have an interesting space available but still be ready to compromise as trade-offs are an integral part of layout planning.
What will you be running?Passenger trains,heavy freight,small diesels or considerably bigger steamers?This choice will dictate grades,minimum curve radiuses,siding lengths,etc.Do you both like the same types of trains?Are you willing to remove most unused rolling stock from the layout all the time?If not,you’ll need some storage track space and that adds up pretty quick.
What do you want your scenery to be?City,suburb,farmland,mining or heavy industry?Again a choice to make.Do you want a basically flat landscape or you like mountains,rivers.etc?There are so much interesting features available that a fairly large area can be filled in no time.
A nice layout,even a moderately sized one is time consuming and costs may soar quite fast and before you realize it,you have invested a lot of both in it so good planning becomes a paramount as you don’t want a layout that you’ll want to tear apart after a while.My suggestion is to build your benchwork when the height is settled and then run trains on temporary installed trackwork
Thanks for the thoughts and inputs.
Nik is now 9. Dad is substantially older. Model trains was never dad’s hobby- not even an interest. Never been to a train show, never bothered to watch a train go by. Nik on the other hand came out of the womb clutching a train. We really are not sure why or how. Since age 1, he’s been playing with trains of some sort. Unfortunately for my wallet, he still likes trains, although trains for kids his age really isn’t a hobby or interest it seems.
We built our first n-scale layout when he was 5. About 1/2 half through (I htought I was 1/2 way, it turned out to be 1/100 complete) we scrapped it and started on a hollow-core door layout. There was ZERO planning for that- I let the 5 year ld dictate what he wanted on the layout. It was good practice on learning how NOT to do alot of things.
We still have the hollow-core door and play with it. We did end up adding a 2x6 section for staging.
What we did learn from our early layout (we can post some pix if anyone cares) is how Nik and how dad like to play with trains. We learned that sometimes we like to put a bullet train on and let it zip. Nik likes to run frieght trains with 50 cars or passenger cars of the Super Chief or Zephyr class. We discovered liking having two trains running on parallel tracks.
When I added the staging yard (mainly so we could spend more time playing with trains than loading\unloading trains), we also started playing with making & breaking trains to run by using a switcher.
When Nik and ( set off on the 1st layout, I was thinking I’ll build this, and be doe with it. (hahahaha) At 5 he really directed the layout which ended up being a couple of dogbones insside each other, a few sidings\passing tracks. Scenery was deemed more interesting then than trains.
Net-Net: at age 9, we still play with the layout alot, but Nik would like more. I’m slowly getting into this hobby too (it’s something for us to share). But at th
John Armstrong pioneered these track planning rationale phrases…
[1] Givens - What you have to work with (ceiling height, room size, train scale, etc.).
[2] Druthers - What adjustments you are left with to actually do things.
For example: N Scale is a Given. Is DCC a Given, or is DC a Druther? Is a single-track mainline a Given, or would it be a Druther because you cannot fit in a double-track mainline?
Each and every Given & Druther may involve a “Force-Field Analysis” with a “Pro-Con” decision. Put a line down the middle of the paper with Pro on the right and Con on the left for each layout function desired to help you get to a Given or a Druther status. What do you need to do to move the Con side to the Pro side?
Givens & Druthers help move things from planning to implenentation, and; comes after must, l
Both are great plans. Neither seems suitable to your given of “big steam”.
It sounds like you already have a layout? If not… I highly recommend building a smaller one to get your feet wet and learn what aspects of the hobby most appeal.
Actually, the Naugatuk was originally published in (I think…) the January 2003 of model railroader half the size of what is in the book. I am not sure why only the larger version is in the database. Anyway, it featured an oval with staging on an “L” along with a small industrial area. The fact it was a loop was hidden and it could be run as either a point to point or round n round. Its a shame its not available in the database because its a nice plan.
Chris
yeah- this will be our 2nd, sort of 3rd layout. part way into the first layout I scrapped it, and moved to a 36" wide hollow-core door layout. From that layout Nik & I learned how he (we) lik to play with trains and what we like to run equipment wide.
The hollow-core door layout suffers from alot of things: I’m not a train guy, have never done model train stuff, and was bumbling around alot. Nik got into building long trains and running long cars (passenger cars, bullet trains). It was a good learning experience, as will be the new layout- will be my\our first attempt at working atlas track- we’ve been unitrack people to this point.
As I see it, you are in a tough spot. Nik likes trains but it is not your thing. But since he can’t build it yet, it is up to you.
That is part of, or even the main problem as I see it that you are facing. These forums are great, but they are for people who WANT to be model railroaders. To get through this, I recommend the following:
  • Get some track planning books. As many as you can. Look through MR’s site and make a list. Check for other track planning books that are out of print and their availability at Amazon.com. Do a search on Track Plan.
  • Look for switching module track plans and track plans that you can take pieces out of. Preferably towns that strike Nik’s fancy.
  • Make copies of these track plans, all in the same scale and cut them out. Most published plans are drawn 3/4 inch to the foot.
  • Make a scale drawing of you bench or table space.
  • Lay these “Towns” and switching modules plans out on you bench space drawing. Move them around until you get a feel for something that you and Nik like. These module plans don’t have to be right next to or connected directly to each other, but can be two, three, or four feet apart.
  • Connect the main running track (mainline) together between modules. Of course you want a loop at each end for continuous running (I saw your bench space drawing in another thread), so that will have to be drawn in unless you find part of a plan you like that already has a loop in it.
As for building the track plan, I would use a brand of track that has the roadbed attached to it. It costs a little more, but you won’t have to ballast the track or put down roadbed. And you may not have to make a lot of exotic cuts. If you go this way, it might pay you to get one piece of every type of piece that is made for the brand that you select. That way, if you need to select a piece, you will have a sample of it to see if it fits where you need it. If you don’t want to go with that type of t
I am going to suggest a different tack, based on your and your son’s relative interest levels and capabilities. One of the dangers in this sort of situation is that by the time you’ve built the thing for the nine-year-old, he’s twelve and might not be interested anymore. No offense to anyone, it just happens with kids. Then you’d be stuck with something you are not very interested in.
[On the other hand, it could turn out that both you and your son enjoy the process and become fascinated with trains for the next couple of decades – could happen, but I’m not sure I would count on it.]
So in my humble opinion, you might be better off with the following plan:
Go with the Sievers benchwork if you like, in a modest configuration that allows you a U shape or L shape with space for turnback curves (blobs) of at least 13" radius.
Cover with plywood
Use Kato UNITRAK (or similar) to build a basic dogbone with a small yard and a few industry spurs.
With this basic infrastructure in place, you can start adding elements as interest, time, and budget allow. This will give both you and your son a chance to try more purposeful railroading while exploring what you like or don’t like. Build on or rearrange as the mood strikes (that’s the benefit of the roadbed track).
A key benefit is that you get up to speed fast – the MTTF (Mean Time To Fun) is vastly reduced and not dependent on carpentry, tracklaying, extensive wiring, etc. (skills you say you will need to develop)
Yes, the roadbed track is more expensive and somewhat limiting for a very involved layout. But if your nine-year-old is like a lot of kids I have known, the ability to build on and change will be a big benefit. Build some structure kits on wooden bases and move them around on this layout and they’ll work on a next layout as well. And you can always reuse the UNITRAK as the staging yard of a follow-on layout.
I’m not sure which Naugatuck you
“…These forums are great, but they are for people who WANT to be model railroaders…”
Now that’s helpful!
Byron-
Thanks for the thoughts.
Appreciate the comments on the narrowness of the layout. We were just fishing for people that have built it- what they changed, liked or disliked. We’ve got a room that’s about 9’x9’ and are working towards a walk-in.
Our first layout took about 18 months. Lots of learning on my part, not much help from Nik- he was 5 when we started. (current layout is 2 hollow core doors, unitrack, block wiring to run 2 trains, with a third set of wiring for the yard)
Benchwork seems like “work”, so we’re going the Sievers route on that. The plan is to get foam down and the mainline loop(s) running. After that we’ll add the other track and scenic along the was as we both have time.
The idea with taking on a larger task here is that we have mostly outgrown our hollow-core door layout. We want to do something that we can add on to later if either or both of us are still having fun, and something more than a loop. Nik has taken over the dining room table with all the leaves as he’s experimented with unitrack. On our door layout, we still run thins and added a 2nd door with a staging\switching yard.
The hollow core door has so many issues (again, it was my “learning” layout) that other than buildings I built, not much else is worth using as a basis for the next layout.
We both enjoy working on scenery. We did a chunk of scenery last winter for someone else’s O-scale.
While model trains weren’t my hobby before my son, they are certainly a hobby now- it’s time with the kid and it’s fun to build and run.
Thanks again to everyone for all the help and advice and patience.
I think the biggest challenge you have in that space is accomodating the big steam engines and bullet trains. I think you would want to consider an “around the walls” design (with a duck under to get inside) to accomodate broad curves for your mainline. Figure 2’ wide benchwork would leave you a generous 5x5 center area.
You could even set it up with one wall having hidden staging that the mainline enters and leaves so trains can appear to enter your layout… traverse it… and exit… the front of that could be a backdrop with a small industrial area in front of that. Perhaps the terminus of a branch line that parallels the mainline with local industries to switch for a portion of the layout.
The only problem would be accomodating a duck under with a layout at a height a kid can enjoy… perhaps a swing bridge or lift out would be better.
Chris
Like the idea of an around-the-walls- have kicked it around.
“Dad” is getting older and ducking under may result in personal injury or just not getting up off the floor. Nik’s Granddad would also be a problem to get under the duck under.
We’ve kicked around the idea of swing-out or lift up gate, but with my limited carpentry skills, we’re going to try to do a walk-in using Sievers commercial benchwork. We want to spend more time on building the layout and playing with it vs. benchwork.
I’d like to have some pretty broad curves, but we think something in the 15" radius curves should be able to handle n-scale big boys. May not look ideal, but they should run.
Thanks again.
Hi, Nic and dad. With a basement layout of 30’x42’ I also wondered how to get ALOT of trees cheap since I model NW Wisconsin. I don’t know how to make the link clickable,but if you type " Fast,cheap and easy trees" into the search thing at the bottom of this page ,it’ll bring you to a tutorial I posted earlier this year on how I make cheap trees. They aren’t Scenic Express, but they don’t cost an arm and a leg ,either[(-D].
Enjoy your time with the son, it really is priceless. My son and I have added the grandson
to the mix!
Terry
Sorry. I didn’t mean that in a derogatory way toward you. (If that what you were thinking.) I was trying to say that a lot of the techniques that you are going to get here as answers are to help modelers improve their skills and techniques. If you are not interested in model railroading, they may not mean much to you. (You said in a post somewhere that model railroading was not your hobby, I think.) As I see it, you are on a MODELING forum but living in a TOY TRAIN world right now. There is nothing wrong with that, but most of the answers are going to reflect modeling views.
No problem. I musta been cranky or forgot to taken my medication.
There have been a number of posts at times (not from you) that has a lower tolerance to real novices. We’ve had the same experiences at some LHS and shows. On the other hand, there’s been some very good folks we’ve met and gotten to know.
The point I was making is that I wasn’t a model train person and leading my son into the hobby. He must have some sort of weird genetic thing that made him love trains from day 1. I’ve started learning the hobby with him.
Yup- we have been in the sort of toy train mode, but even our first layout had alot of secenry. We added a yard to make and break trains, and we’ve had fun with that too. Our next one will strive to do some operations. the idea is for this to be fun for dad ot play with and for Nike to continue to grow with.
So apologies and thanks. Yes, we have alot to learn. But we are moving from toys to modelling. Maybe this weekend I’ll post some pix of our little layout.
Have a good weekend
I think I would steer Nik away from the extra-long (extra-expensive) trains like California Zephyr and towards shorter stuff. The beauty of N scale is that you can build much more scenery to overshadow the trains; long trains interfere with that unless you can take over the basement.
Try this (or call me a nutcase and don’t try): prop up a 4x8 on a modest tilt with the back long side higher than the front. Build whatever sounds interesting switching-wise in front. The back side - which can be set along the wall - is flat and straight; a speedway. Nik can charge across the countryside in the back and slow down - he’ll have to; he’s coming downhill - to arrive in town.
A few buildings in the middle of the table will act as viewblocks for the back tracks, if you build the table near his shoulder height.
