I just got done assembling the motor house and I tested out the motor.
The motor’s speed isn’t consistant and it’s somewhat noisy even with greese. Sometimes it stalls to, even at 5 Volts which has me worried.
I see the central drive shaft spools in and out, and that’s causing some gear slapping against parts. I’m suspecting this is the majority of the problem.
Has anybody else experienced this? Did you come up with a solution, or will it go away when I connect the rest of the bridge with it?
