In a recent thread there was mention of using bolts wrapped with aluminum foil to simulate pipe loads for flat cars. Well, being into cheap, I decided to do some galvanized pipe for use along the tracks. Problem is, pipe is hollow, bolts aren’t! The other day I ran across some threaded hollow rod that was left over from “honeydo” light fixture hanging projects in my toolbox. They’re about the right diameter for large culverts in HO scale so I used them for detail parts. It’s very easy, but here’s how they went together…
First, paint the ends and inside of the rod silver.
Next, cut appropriately sized strips of aluminum foil. I prefer the “heavy duty” variety to resist tears.
A small piece of scotch tape was used to secure the foil to the rod so it could be tightly wrapped. The “dull” side of the foil looks right to simulate a galvanized finish.
Use your fingernail to gently add the “corrugation” to the “pipe”. When finished, touch up any areas that need it with silver paint.
Well, they aren’t perfect but they are easy and cheap to construct. They also add detail!!!
Happy railroading!
