Does any body know the approximate overall dimensions and approximate radii of a HO scale code 70 #2 nad 1/2 wye? Need the info for a possible track revision. Thanks
Old Fat Robert
Old Fat Robert
You have to specify a brand to talk about radius - the number is only indicative of the angle of the frog. The radius can and will vary from brand to brand, or line to line.
Robert,
Here’s what I found out from this .pdf page on turnouts:
The two routes curve in opposite directions, which can save space in some tight situations. A #4 wye matches the frog angle of #8 turnouts and a #3 wye matches the frog angle of #6 turnouts. However, the closure radius of a wye turnout is much smaller than the closure radius of the matching conventional turnout.
Here’s what the same .pdf says about closure radii of the following turnouts:
At a minimum, it will be under R15" and, perhaps, a single-digit radii. Pretty tight for all but the smallest of switchers and rolling stock.
The only one I am aware of is one made by Shinohara. I have e mailed them but have yet to receive a reply.
My error. I meant to say the only one I know of is made by BK Enterprises aka Trout Enterprises. I am sorry if I mislead anyone.
Old fat Robert
Tom: Thank you for your input. You obviously have a greater grasp of this subject. Using the info you supplied, I computed the difference between a 4 and 5 at 57%. Following that logic (?) I came up with a radius of about 8.5 inches. That will certainly do for an interurban line that has a single 40 foot trolley in operation.
Robert
Not necessarily a greater grasp, Robert…Just a knack for googling an answer.
Anyhow, glad that helped. I actually saved that .pdf file into my Train folder for later reference.
Wye turnouts are half though, they split the difference between the right and left leg, rather than having all the radius in the diverging leg. So a 2 1/2 wye is going to have a frog angle and radius equivalent to a #5 turnout. It won’t be under the 15" radius of a #4 turnout.
Dang, Randy: You just shot my track plan theory down!! ALthough I must admit that what you said makes a lot of sense. Thank you for the input.
Old fat Robert
Looking at the Fast Tracks site for HO fixtures.
A #4 wye turnout jig (smallest they offer) has a diverging radius of 43". The equivalent straight turnout, a #8, has a diverging radius of 67".
So a 2 1/2 will be something less than 26" for a #5 per NMRA RP12.3.
Multiplying 26" by 43/67 = 16.69". Note that this may not be a valid extrapolation. It’s also possible that the actual turnout is made to have a larger diverging radius.
I suggest you get a 2 1/2 wye and measure it.
Good luck
Paul
Thanks Paul. I am attempting to get my hands on one. As mentioned before, I have e mailed the only maker that I am aware of for specs. Am waiting for their reply.
Robert
