Are you referencing paged mode programming (which isn;t this at all) or the concept of paging as a method of handlign indexec CVs for systems that can set a CV over 255?
The NMRA seems to freely mix up 0 based and 1 based counting. Since there is no CV0, the range has to be 1-255, 256 requires 9 bits to represent. ANd then is 0 skipped every time thereafter as well? IE, from an engineering/programming/how basically every digital computer works, you’d have 0.1-0.255, then 1.0 would be the equivalent of 256. Or do they use 1.1?
All this cobbling on is what happens when the use far exceeds the capabilities of whate exited when the original specifications were designed. Back in the day, there were no sound decoders, and even with a 28 step speed table (possibly a reason why there was no 128 step speed table is because it would use too many CVs) and multiple effects across 4 or 6 function outputs, it was nowhere near using 255 CVs. 255 CVs should be enough for anyone (just like 640K RAM should be enough for any computer, now a $2 microcontroller chip has more.)
Thanks Randy. I am talking about indexed CVs. I understand Paged Index CVs are for 257-511 (so 1-256 and 512-1024 are normal CVs).
Can I assume that when you read/write to CVs 1-256 or 512-1024 that the value of CV 31 and 32 doesn’t matter? And that the page index is only relevent when you are working with CVs 257-511?
