My C-16 has problem ( intermiten ) when power is applied it act’s dead, when i tap the tender it starts going. any cheap soliutions to this problem? Wheels, pickups and engin lubed .
When was the last time you cleaned the wheels? I have to clean mine pretty regularly. A bit of CRC2-26 (or WD-40 if you have to) on a Q tip will do the trick.
-Brian
Thanks I will try cleaning the wheel treads, I lubed the back side. this engine has only been run once before on brass track. I well post the results when I run it next weekend.
Thanks, Dave
Thanks the wheel cleaning helped and so did adding screws to the track connectors.
