Sometime back, actually a couple of sometimes back I bought online from one of the big dealers two of these babies with different roadnames. Obviously from different lots so the problems I had should not have happened twice. I put the first one on the track say about eight months ago. The pilot wheels would not stay on track on my LGB switches. Finally changed out both metal pilot wheels with two of the generic ones I had in my parts box and that did the trick. Stayed on track through the switches no matter what.
Thinking that this had to be a one of a kind fluke I put the other one on the track Sunday. Same exact problem. Thats the last one I’ll ever buy of them.
Has anyone else had this problem with this engine or am I jinxed?
Jinxed? Probably not. But did you check the wheel gauge of the pilot truck? Assuming that the wheels derail because they are plastic and too light, have you tried adding weight? Contact Aristo and see what they say about the problem. Maybe they’ll send a free replacement pilot truck or tell you how to correct the problem.
Rudy, remove the pilot truck’s, place in a small vice, tap on one end with a small hammer, check with a track gauge IF you have one, if not try going through a switch, replace wheels .CHEAP & EASY
You can make wheel gauge from a anything wider then 60mm, just make your cut’s 45mm apart and no more then 1/8 wide , a chunk of 1x2 3inch’s long shoud work, use a piece of track for cutting template. Or send me an E-Mail with your number and we will talk.
I looked at some of the Aristo small wheel sets I have and they appeared to be a touch narrower than others. Its not a problem on my layout but I don’t have any LGB switches. If yours look like these -
they are a composite of metal and plastic.To regauge them, you will need to remove the axle tips and the wheels apart. The wheels are attached to plastic half shafts that slip over an inner metal tube shaft. Once you pull one wheel/half shaft off, you can put a small metal or plastic washer(s) over the inner shaft to shim out the wheel. You can get small brass or stainless washers in baggies at the home depot. The steel washers used with pop rivets will probably work, too.
I PURCHASED MINE FROM ST. AUBINS AROUND THREE WEEKS AGO.
TODAY I WENT TO TRAINFEST IN MILWAUKEE, WI AND SPOKE TO A MAN IN THE ARISTO-CRAFT COMPANY BOOTH (POLK’S MODEL CRAFT HOBBIES). A NUMBER AND PERSON TO ASK FOR WERE GIVEN ME.
That looks like them for sure. Another issue was I had to really hold my tonge to the left to hold the springs and the contacts in place during the replacement. Luckily I found them all when they went flying.
The wheels I used for replacements were the generic ones made by Bachmann and others. Just a little larger in diameter but they did the trick.
Good luck and let us know if they know that some of their merchandise does indeed suck.
I went the role of calling and emailing Wholesale and Aristo before on another item I bought that came in damaged. Got no where except getting into a sharp email exchange with the guy that owns Aristo.and hate emails with Wholesale.
