Aristocraft Transformer # 55450
Just a quick question? Does this whole package produce 10 AMPS of power? I found this power pack and throttle number 55450 on trainworldonline.com and was wondering if it produces 10 AMPS of power to the track? I was also wondering if this power pack comes with cables and if I can use 12 or 14 gauge wire with it?
Any help will be greatly appreciated
No. That power supply is only listed for 3.5 amps - http://www.trainworldonline.com/catalog/detail.php?ID=2641&SECTION_ID=313
If you want 10 amps you’ll need the Ultima power supply with the 10amp controller (55460/55401).
It will come with wiring to hook up between the power supply and the controller but you will need to provide your own wires from the controller to the track.
-Brian
Could I combine the 10 AMP Control Pack Adapter (55401) with the Ultima 10 AMP Power Supply (55460) by Aristocraft.
Thanks Again
Yes, that’s what I wrote above.
-Brian
