Someone asked about the difference between the SD40 and SD-40-2 in the January 2005 ASK TRAINS
They correctly pointed out the longer frame (for commonality withSD45-2) and modular electrical system and the minor things like the water level sight glass (well, actually the window to see it without opening an access door).
But on the trucks they missed the boat entirely mentioning only that the Dash 2 has the dampening strut. (What, no mention of the three holes in the frame instead of two? ha ha) NO NO NO. The difference between the HTC truck found under most (e.g. not Conrails’) Dash 2 C-C’s and the Flexicoil truck previously used is much more than a dampening strut and holes in the frame! The HTC truck lines up all the traction motors the same way instead of tucking them all inboard of the axles. This means that one of them is outboard of an axle and you can see how the truck frame is extended to carry it. That is an additional visual difference beside the holes and the strut.
The purpose of this change is significant. It reduces weight transfers that would occur under heavy pulling on the old truck. The traction motors are hung NEXT to the axle with a pinion gear on the motor shaft driving a bull gear on the axle. One end of the motor hangs off the truck frame while the other rides bearings on the axle inboard of the wheels. This allows the axle to ride up and down on its suspension following track irregularities and the motor tilts up and down with it. But the motor also tries, with the forces involved, to either climb up or push its way down depending on which way it is turning. It doesn’t really do this but it tries to in a manner of speaking. When two motors are facing one way and one is facing the other way you will have two trying to lift and one trying to push down…or vice versa. This causes a transfer of weight between axles and the axle that has weight taken from it is more apt to slip. Which in turn means the wheelslip control system must redu
What was the exact question “Ask Trains” was answering? If it was “How do I tell an SD40 from an SD40-2?”, it may not have been considered that this was the right place and time to discuss weight transfer characteristics of EMD trucks. For the average observer, watching a moving unit, with trucks covered in road dirt, the damper strut would be the easiest truck feature to see if you were on the wrong side to see the sight glass. I can’t count handrail stanchions fast enough to tell the frame length on a moving unit.
It sounds to me as though “Ask Trains” were correct, if not comprehensive in their description of the SD40-2, and rather than a “correction”, additional information could be provided in a letter.
Why don’t you write a letter to “Trains” providing the additional information, and if it is printed, you’ll get paid for it.
I’ve only recently discussed this aspect of truck design on the “Steam Diesel and Electric” thread on this Forum, and what I said is pretty much the same as what you said. It isn’t news to many of us on the Forum, but I didn’t specifically indicate that that motor arrangement was used on EMD Dash 2 locomotives.
You may be surprised to know that trucks of that design were used on EMD export designs prior to the introduction of the Dash 2 line, in particular the GT26C locomotives built by Clyde Engineering for the Western Australian Government Railways, built from 1967, had a version of the HTC truck, at least four years before the Dash 2 units were introduced. Those trucks did not have the damper strut on the centre axle, either!
Also, Conrail specified the older style flexcoil trucks with their purchases of new SD40-2’s in the 1970’s…they were leery of the newer truck design because of the blame( though never fully proven) of the newer style trucks on derailments of the Amtrak SDP engines in the ealy to mid 1970’s. Dave Williams http://groups.yahoo.com/group/nsaltoonajohnstown
Right , you can’t tell a dash 2 by the trucks. The only real way is to open the electrical cabinet.
Randy
[/quote]
Cool, if I am even on an SD-40 I will open the electrical box and say “cool it is a dash-2.” I figure I will have a better than 50% chance of getting it right given the number of Dash 2s compared to regular units.
Gabe
[/quote]
Another spotting feature, though not always accurate, is the style of radiator grills on the side of the long hood. SD40’s had the chicken-wire flat grills…40-2’s have the raised ribbing…Conrail rebuilt 40 SD40’s from KCS, and Penn Central/Pennsy heritage and upgraded them to SD40-2 status internally but left the external features as 40’s…they still had shorter frames and chicken wire radiator grills. They are still in operation, having been divided up between CSX and NS after the merger. NS’s are used in road service, and also serve along with the as-built SD40-2’s in Altoona helper service…If you see an NS SD40-2 with a number of 3425 or higher, it is one of the former Conrail 6900 series rebuilds…the chickenwire and shorter frames will give it away too. Dave Williams http://groups.yahoo.com/group/nsaltoonajohnstown
Gabe
[/quote]
Hell yes … Anything over 50% is great odds.
Randy
[/quote]
Another spotting feature, though not always accurate, is the style of radiator grills on the side of the long hood. SD40’s had the chicken-wire flat grills…40-2’s have the raised ribbing… Dave Williams http://groups.yahoo.com/group/nsaltoonajohnstown
[/quote]
Actually, early production SD40-2s carried over the chicken wire grills, corregated grills were phased in in the mid-70s, along with other minutae like anticlimbers and 88" noses. The truth is, after up to 32 years in service, spotting on the fly is a nightmare. I am a reformed rivet counter myself, and if see an SD40-something go by, I am happy to call it an SD40 in the field. In the same way, I just talk about ‘geeps’ and ‘switchers’ to discuss 1949-1961 and 1939-1966 production respectively, the parts by this time being so scrambled that arguing over models, much less phases, is pointless.
Just know what is ‘normal’ so you can spot oddballs, then go home and look them up. Of course then the ‘experts’ can’t decide whether a 16 cylinder SD45 rebuild is an ‘SD40-2’ or an ‘SD45m’ themselves, so just do what you need to to get your point across.
If I remember correctly the GE export model for New Zealand Dx class had strut and traction motors located in same direction. Different builder, not sure of the year.
The NZR U26C (Dx) certainly did have unidirectional traction motors, and a short truck wheelbase, but retained a conventional truck bolster. This was an improvement on contemporary domestic GE trucks, but the NZ units appeared late in 1972, (in service in NZ 11/72) after EMD’s Dash 2 line was introduced in that January. Photos of the units as built do not show any damper struts. The NZ units were among the first of this design.
The way I use to ID locomotives, is use the 'road’s equipment roster.
Big Jim Kerr, buys full page adds in the mags, has comprehensive, accurate coverage, and includes shortlines, and industrial units.
Mr. Kerr updates his rosters regularly, and offers discounts occasionally.
The occurance of pool power has made it practical to own this valuable resource!
