Athearn 2-8-2 light bulb replacement?
I have an Athear Mikado i would like to replace the bulb I’m converting to DCC. The bulb seems stuck I broke the wires leading to the bulb can some one tell me how to remove and install LED?
I would just break the bulb then remove the pieces, a 3mm warm white LED should work OK. Follow the decoder instructions to hook up the LED.
Mel
My Model Railroad
Bakersfield, California
Athearn used to use school glue to affix bulbs in locos. It can be softened with water and the bulb should come out.
