Athearn axle gear p/n 60023 (the old p/n)
Anyone know a source for the above ATH axle gear p/n 60023. I have some metal outside framed Athearns that need to have their Ernst gearing removed and I will need some of the 60023s to replace the Ernst axle gears. My usual sources are out and there are none on Eb ay.
G. T. Galyon/Olde Newburgh Model RR Club.
Maybe Athearn Parts Dept?
What loco and model year is that part from? I looked through some of the Athearn drawings on the http://hoseeker.org/athearn.htm site and don’t see that part shown anywhere. Is is part of the wheel assembly?
There is a guy who advertises in the back of MR that always says he has Athearn parts. Haven’t dealt with him myself, but he is listed as R J Rennie, 440-234-7186. He is in Berea, Ohio.
Redudub1
You can try,wwwhobbywarehouse.com 1-888-503-4677,They stock Athearn parts,I noticed that they had the part#60024 in stock,I didn’t check any further,give it a shot…
Cheers,
Frank
They are on ebay all the time. I don’t remember which seller I got them from but he has a lot of listings all the time. I think I got a package of 6 for $4.00. Roger Huber
I couldn’t find it on HOseeker either. But all my old outside metal frames have this old axle gear p/n which according to one of my regular sources IS 60023 (as opposed to the newer 60024. These 60023 axle gears have a wider diameter gear (by about .1mm) and longer hubs which fit flush to the running wheels (with no intervening bearing). Fortunately, the bores are the same as the 60024s.
I will try your source…thanks.
REDVDUB1,
The ones I mentioned,from Hobbywarehouse,the 60024,look exactly like your description…
Good Luck!!
Cheers,
Frank
