Does anyone have a DCC adaptor board for a new athearn loco. I fried the light bulb contacts on mine and need another one. I could order one from Athearn but it would tkae 4-6 weeks to process my order. My loco is a C44-9W but any DCC adaptor board should fit.
Sure Smoke. Since I put sound decoders in most of mine, I happen to have a few laying around, cluttering up the work bench. I even bet I have a Dash 9 one on the corner of the bench now.
Are you talking about the ‘decoder’ board? If so, you may have ‘fried’ the 1.5v Genesis light bulbs. Most decoders put out a full 12-14v for the light outputs. You need a resistor in series with each light to drop the voltage. A 470 ohm resistor should do it, but the Athearn bulbs are notorious for being all over the place. I would buy a selection of small 1/8th or 1/4 watt resisters in the range of 570 to 1000 ohms and test first.
I didn’t fry the light bulbs just the hook up. here is a picture of what I fried. If you look to the left side you can see the hook up that is toast. I need the whole green board not just the “plug”[IMG]http://img474.imageshack.us/img474/9960/img6352xv1.jpg[/IMG
The check is in the mail and soldering is always tricky. I did not include the jumper board, not because I don’t have them, I just forgot. From the picture, it looks like it is ok anyway. Probally Monday or Tuesday before you get it, depending on the USPS.
