Athearn DCC Ready Questions
So I am planning on purchasing an Athearn U50. The description on the model says that it has a dcc ready wiring harness. Can some one explain what that is? Is it like the BLI Blueline? Where one removes a dummy chip and insert a dcc harnessed decoder? If that is the case, it would be fairly easy to install a mobil decoder.
Secondly, if one wanted to install a sound decoder, what is the easiest means to achieve that? I am assuming that sound decoders will require some soldering. I am partial to the tsunami sounds. Are these difficult to install compared to other manufacturers.
Thank you in advance from a novice.
Esentially, yes. Athearn locos with the DCC Quick Plug have a 9 pin plug with a dummy plug in it a small board with some diodes to control the directional lighting in DC. You pull that off and connect any decoder that has a 9 pin conenctor on it. Get a decoder with a 9 pin plug and no harness.
For Sound, there is a Tsunami in the form factor of the Athearn circuit board. Since all the wires on the board are held on with those little palstic caps, removing the factory board is easy. The connections on the Tsunami are in approximately the same physical location. The decoder is, easy, mounting the biggest speaker and enclosure you can fit is the hard part. The problem is there is currently not a Tsunami with the proper motor sounds for a U50. Nor anyoen else’s, at the moment. You’d have to go with one of the generic GE FDL sounds, although the U50 has twin diesel engines.
Randy,
Thanks for the info. As you mentioned I found the generic GE sound decoder on the soundtraxx website. I also looked up the install manual. It doesnt seem to difficult.
On a side note, is their any indication that someone may release a true U50 sound decoder?
Thanks,
Just guessing here, but since they all were scrapped, there aren’t any around to make recordings from. And since there were only a few produced, it is not in great demand.
Since it was basically a pair of U25’s in a single carbody, it probably can be faked with a U25 recording. The new QSI decoders with stereo capability is going to make possible some really good dual-motor applications, like E units.
Great. I am going to look into it.
Thanks,
Randy,
I cant make left to right on the QSI website. Do you have a suggestion on the specific QSI decoder? I am assuming its a Titan, but can find part numbers with the specific sound files.
Thanks
Simulating dual prime movers in the below link.
http://www.mrdccu.com/curriculum/soundtraxx/tsunami.htm
Store the link in Favorites. You will need it. Study the Curriculum links also. A lot about the Tsunami and sound.
They don;t have a U50 yet in the Titan, I was just syaing that the stereo feature means it will be possible for someone to do it, and do it right without using reverb to simulate it. I suppose another option, since it’s a large loco, is to use 2 decoders. Would really work if the loco has 2 motors, one driving the front set of trucks and one driving the rear set.
I have a U50 on order right now and have been doing some research. This link might help you out for a kit that is ready for the U50:
http://www.internettrains.com/merchant2/merchant.mvc?Screen=PROD&Product_Code=IMT-SOUNDATHU50&Category_Code=HSCLOCDSLATHRTRU50
I haven’t decided whether I am going to use the Soundtraxx or the QSI yet…Brian
Mark, from Internettrains, write me yesterday that SOUNDTRAXX is right now improving the sound decoder for the new Athearn U50. It will be available in 4-6 weeks. I´ll prefer to wait it.
