Will an Athearn blue box F7A or F7B shell fit on an Athearn Genesis F7A or F7B frame?
Probably with some modifications but, why would you want to? The Genesis shells are much superior to the Blue Box bodies.
C’mon, Bob, 'fess up.
What did you do to that Genesis shell?
Maybe He doesn’t have a F7-B Genesis shell and wants to use the BB, B-unit shell,or vice-versa.[:-^]
Cheers,
Frank
What would be the vice-versa?
The A.
Cheers,
Frank
ahh, which do you think it is, Frank?
Honestly! I really don’t care. No offense,to the OP,This has been discussed,many times and unless Athearn changed they’re chassis,they are the same,except for the drive and motor.
Cheers,
Frank
Will a BB F7A chassis fit on a Genesis F7B frame? Or, vice-versa?
Should he Google for the answer? [(-D]
Rich,
Yeah,Probably should,because this very same thread,is already in there…Along with many other MR,Forum threads…
Cheers,
Frank
Rich,
I also believe,You should have given Him the answer,rather than ask,why He wants to do it.[:-^]
Cheers,
Frank
That was Jim who asked that question in the first reply. [^o)]
Incidentally, when I Googled it, there are mixed opinions on whether the BB and Genesis chassis and shells are interchangeable or not.
Well I for one can only say; I don’t know…
Why, the Genesis are built on Highliner Shells not the BB ones.
I do know & contest that the Highliner shells will retrofit on to BB frames, but I remember putting them in the Mill to back set Drill & Tap the Coupler Screws for better appearance.
I will go with the Answer , that anything may/will work with modifications.
One may have to add or remove material, &/or beaching stops so the shell will have positive seat on the frame.
Thanks,
Rich,
WOW!! Really no kidding?[swg] Everyone has a different answer,for the same question.
I will though agree with what Chad,replied,most anything is possible,with a little work and fitting.
Cheers,[D]
Frank
Amen to that! Many of my creations are proof of that.
True, but I have a feeling that the OP is hoping to hear that the shell and frame are interchangeable, and from what I read, I don’t believe that is the case.
True, but I have a feeling that the OP is hoping to hear that the chassis and frame are interchangeable, and from what I read, I don’t believe that is the case.
I believe,you mean,the shell and the chassis.
Cheers,
Frank
Cheers,
Frank
Frank, you’re killing me. That’s twice in 24 hours you have caught my gaffe. I am totally losing it. I fixed it in my prior reply. Please stay with me, I need your continuing guidance. [angel]
Cheers,
Frank
What was the Question?
