Athearn FP Genesis DC to DCC
So I want to convert a Genesis F B from DC to DCC. I am aware that I should use a TSU-GN1000 EMD. Anyone have a suggestion for a speaker and enclosure? And /or what diameter I should be looking for?
Lastly. Would it be possible to use a TSU-1000 and just plug it into the existing jumper?
Thanks
So I found the below at tthe SoundTraxx site. EMD FP45 TSU-GN1000 828051 decoder.
810054 speaker
Baffle 810110
The TSU1000 could work depending on the space avaialble.
Thanks for the part number…
Cheers
The F7 does not use a 645 diesel power plant. Here is the correct information off the Soundtraxx web site:
Model Decoder Model Decoder Part # Speaker/Baffle Kit #
EMD F7 TSU-GN1000 EMD 567 828050 810054/810110
Here is the web link to the Soundtraxx Tsunami decoder selector:
http://www.soundtraxx.com/choose/step3.php?t=ho&s=Athearn
The decoder model names for the Tsunami decoders can be sort of confusing with the similar names, but different part #'s.
Jim
Thanks for the correction.
Does anyone know if I can use the same wire clips from the original light board on the GN1000?
Thanks. The FP and the FB confused me.
