Athearn Genesis DCC headlights
You just need to set the CVs for Mars light effect, same as the strobe. NCE decoders run LEDs fine, but they do have a setting for that - if it’s set for LEDs and you have an incandescent bulb hooked up, the effect will be poor. Depending on which output it’s CV120 through CV123 (white, yellow, green, violet in that order). A value of 8 is a none-directional mars light for incandescent bulbs. For LEDs you add 128 to the value.
I use the DA-SR decoder in my Athearn Genesis F7A locos, but all three of the NCE decoders that you mentioned provide the desired Mars light effect.
The Mars light on NCE decoders uses Output 3. The factory default setting is CV35-4. To replicate the rotating beacon, program CV122=9.
