Athearn GP-9 correct scale?
Is this one of the Athearns that has a too wide shell?
Loco
Your link doesn’t seem to work for me. Takes me to the Trains.com Forum Page.
I know Athearn did have a problem with it’s Blue Box SD45. For what I know it was 2 or 3 scale feet wider than the real SD45. I’m not sure if that helps as it not the same locomotive!
OK, I fixed the link. I have no clue why it went to the main forum site [#oops]
Too wide.
David B
From the sellers description, it may be a dummy unit!!! What was the latin for buyer beware?[%-)]
I know it is a dummy, dosn’t fit my era, I was thinking relic in the yard [#dots]
The problem with the Athearn GP-9 is that the shell is too wide. Also, it’s GP-7.
caveat emptor [;)]
-Brandon
get the Proto-2000 GP-9 or an Atlas GP-7. Better locomotives, better bargains.
Hey - leave me alone - I’m old!![|(]
Yes. I’ve stayed away from the BB locos for that whole reason.
I believe that it’s only the older BB’s with the open motor that was too wide. Athern has corrected it on the newer models. [:)]
Only the earlier Athearns were wide bodies.
Wide Bodies:
GP7
SW7
S12
GP35
SDP40
SD45
SD9
All of their GE’s
The first scale hood width unit that they came out with was the SD40-2 in the 80’s.
Dan
The older Athearn hood units were about a scale foot too wide. I run them with some of the scale width Athearn units and it isn’t all that noticable.
As stated the Athearn GP9 is actually a GP7. I make a kind of faux GP9 by removing the two louvres under the cab and the louvre on each side of the hood that is just past the dynamic brake blisters.
Having been out of HO-Scale for more than a quarter of a century I don’t know whether Uncle Irv and Company ever retooled the body shells for their GP7/GP9 but if they didn’t then this is most likely one with a 7 foot wide HOOD instead of a prototypical 6 foot wide HOOD.
I disagree with forum member Mr. SP; when these are coupled with a scale-width unit and viewed from above this oversize hood-width becomes readily noticable. In the mid-'70s when Atlas made their first HO-Scale offerings with their scale-width hoods I saw one of these “dummies” mated up with an Atlas unit and it was one of the first things - indeed probably the first thing - which I noticed.
Looks like I have one of the older Athearn SD-9 shells. Just checked and it’s seven scale feet across the front hood.
The SD9 looked good enough that it was easy to look past the width. The problems with the GE and GP35 and SD45 models was that the front windows were a total mess, not even close to looking good, mostly on the EMDs. Also, and not to get too picky because I still liked the model, the SD45 had too many engine access doors and too few radiator grills.
