I have been looking at and searching thru the IC loco roster and can’t find any reference to an SW 1500, I did finally find a pic of one from 2010 number 1505 and it doesn’t look anything like the Athearn model. Does anyone know what type loco it really is?
Once upon a time there was a model of the IC engine with the angled roof sides. Can’t tell you who made or if it is up to current standards. Probably 20 years ago.
I am reasonably sure it is because fabrication via weldment from plate is simplified with the design. I see references that mention standardized construction or details in common with the design used for the GP35/38 which I believe involved easier welded fabrication.
I note that some of the doors on these units appear to have come from earlier cabs, and have curved ‘heads’ that do not match the new ‘roofline’!
The cabs look an awful lot like EMD spartan cabs as found on GP/SD-35 and later models. It is could be that IC(G) added spartan cabs to former “calf”, cabless switchers using cabs salvaged from scrapped locomotives. If the cabs were purpose built, eliminating the curved roof would ease construction, and be cost-effective. If I were going to build one of these critters in HO, I’d seriously consider the Cannon & Co. 35 line cab kit.
I just talked with a retired IC employee who was involved with rebuilding the SW9s. He said with the rebuild the old cab wouldn’t work and the tapered roof was easier and cheaper to make. EMD eventually took some of the engines as trade ins and copied the cab styles years after IC made the change.
