Athearn Part Numbers Needed
I have a second hand Athearn CSX C44-9 but it needs some parts and I don’t have the directions. I need a replacement front front drive shaft for it.
Also can someone tell me the part numbers for all of the accessories such as the horns and bells up top, hand rails, and the plastic gas tank covers on bottom.
If someone has this direction sheet and could scan it up then that would be great too!
Thanks
Ok. By the front drive, I assume you mean the “spline” which is the connection piece between the two worm couplings. The spline is part # 90109.
The accessory set is part # 49417. This has the horn, antenna, sun visors, ditch lights, brake wheel, exhaust stack, sand fill hatches, and exhaust stack base all in one bag. Can’t get them separately.
The hand rail set is part # 49401. The stanchions for the hand rails are part # 10429 for the long ones and part # 10428 for the short ones.
The fuel tank is four pieces. The left side is part # 49412. The right side is part # 49413 and you will need to add the air tanks, which is part # 49414 (includes both tanks). The left fuel tank cover includes the bell; it is molded in.
I have the sheet as well and have scanned it into a .jpg file. Let me know you email address and I will send it to you.
Warren
Thanks again, that’s just what I needed!
