Just pick up two of these after a 6 month wait. What a treat Athearn RTR with can motor right out of the box. The only problem is front and rear rails are leaning inward. they are made out of plastic does anyone have an easy fix for this? Thanks, Truck
As far as I remember, the front and rear railing are a press fit into the shell. Try pressing them in a little harder and that may do the trick. Also just leaving the locomotive out on the layout for a while may give the plastic railings time to straighten out and shuck off any set they may have taken from being packed tightly in the box.
