John,
First let me say that I have considerable experiance in hand layed track, so nothing about the CV turnout it was difficult or new to me. I will say however that I was not crazy about the idea of glueing the rail as they recommend. In any event, the glue issue had no effect on why I was not happy with the results.
First problem - the frog, as provided in the CV kit, is a small piece of plastic that recieves the two rails after you file them down. What they failed to tell me was that Atlas code 83 rail would not work correctly. That was what I had on hand.
Second problem/concern - the points are a soft cast metal, and while very detailed are also very fragile. I had no problem assembling them per the instructions, but as I made test runs with various locos they seemed loose and wobbly.
The throwbar is also a very prototypical detailed set of plastic castings, but required glueing for final assembly, leaving no way to repair or ajust it later.
The final product, while very detailed proved to be very fragile in the testing that followed. The points became loose in their pivots, and the throwbar, dispite being glued, failed to stay together under repeated operation.
I read later many people are using the CV tie strip but building their turnouts in the popular conventional manner with one piece closure rail/points, rather than using the CV points. Additionally, many are using frog castings from other manufacturers in place of the CV plastic frog.
It seems to me, that if one is going change all those parts, why not just use FastTracks or roll your own completely.
Personally, I now use Atlas code 83 track and turnouts and am very happy with the results.
When I do need a custom turnout, I disassemble a #6 or #8 Atlas and use the points/throwbar and frog to hand lay whatever curved or
