Just got an Atlas 8-40c. Sounds really good. One small issue is that when in consist with a locomotive of a very similar type, the front truck comes off the rail on both locomotive. Works fine running alone. Anyone know whats up with this?
The two locomotives are probably running at slightly different speeds. Try arranging them differently. If you have DCC you might try adjusting the speed ranges so they match.
Will give that a try.
