Atlas BDU and SCB boards
Does anyone have anything that identifies the signal pin assignments on the Atlas 235 and 239 signals with the Atlas “Block Detector Board” and the “Signal Control Board.” OR the Tomas HO #H-874 and the #H-861. I’m going to try and switch my Atlas melting switch machines with the Tortoise ones and the signals on the track side AND an led on a panel to indicate the turnout direction. Gees, I ask you guys for alot. Thank you all very much. Anything at all is appreciated.
Trev
Would that information be contained in the Atlas signal system operating manual?
http://www.atlasrr.com/pdf/Instructions/Atlas%20Model%20Signal%20Manual.pdf
