Atlas code 100 bumpers (and lights)
I have 2 Atlas code 100 bumpers. they have a hole on top of them, as if they were expecting a light bulb to be there. Would it make sense to put one there to indcate a siding is active, and if so, what type of bulb would I use?
What road and era do you model?
A 14/16v grain of wheat will fit and i’ve seen red LEDs put in them too with a resistor and full wave rectifier. Radio shack has blinking LEDs that will fit and run on 12v but it would still need a rectifier and limiting resistor. Walthers have some better looking bumpers that look like they are made of welded rail and look more prototypical than the Atlas ones. FRED
Fred,
Just for reference… Not flamin’ just explain’. A rectifier converts AC current to square wave DC. LEDs work on both DC and AC power so you do not need to add the rectifier. The resistor is needed to reduce the current flow through the LED and must be added in “series” with the LED not “parallel”. i.e. |pwr|–|resistor|–|LED|–|gnd| and it doesn’t matter which side of the LED the resistor is on, pwr or gnd it is there only to limit the current. For most LED applications a 870 - 1k (1,000) ohm is satisfactory. The higher the resistance the dimmer the light. In some of my buildings I have put 10k resistors because all I wanted is a very dim glow of light. However, I don’t recommend less than 870 ohm as an LED will burn out if to much current flows through it.
LEDs come in many different sizes. From X-Lrg 10mm diameter to the new Micro-Mini 1.5mm. (http://207.234.141.88/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=6_1)
I seem to recall Atlas did have a bumper with a light on it. (And I think Tru Scale did too,and of course such a bumper was a classic old Lionel item). Maybe they use the same casting for their “dummy” bumper, but I doubt if it is wired.
There is something to be said for using such a bumper in, say, a stub ended staging yard that is on a lower level or in the dark so the operator can see where the end of track is , but there are circuits that accompli***he same goal more effectivly
Dave Nelson
WELL, Just for your reference… Not flamin’ just explain’. You need a full wave bridge because LEDs are polarity specific devices and when a train on DC backs up the polarity on the track reverses. If you install a full wave and hook the “ac” terminals on the full wave to the track the LED stay on all the time, not just when the polarity is correct… I also never mentioned the word “parallel” or “series” in my answer. If the poster wished to use a LED I would assume he/she would ask how. Also not all LEDs require the same voltage and current so your recomendation to resistor size is suspect. To further the point, there is a voltage drop across the full wave that also has to be factored in. I could also use a 12v LED and full wave and it would likely work without a resistor at all. You could also buy one of the new LEDs that change color on polarity reversal. You could also go to Walmart and buy a pair of shoes w
Fred,
You are right in all aspects. I know that I am just an 18+ year IT engineer with no knowledge of electronics and I applogize for trying to help all that read this forum.
