OK, let’s summarize where we are at with this issue.
You have a problem with your 4-axle locos stalling on all of your Atlas #6 Code 83 turnouts.
We are not sure if you have more than two locos, but the two locos that are stalling are an Atlas Trainman RS36 and a Walthers Proto 1K GP15. Power is getting through both the front and rear trucks.
The locos stall at the frog when the turnout is set to run straight through, but the locos do not stall when the turnout is set to run through the divergent route.
The turnouts are not wired on the ends of all three legs with feeder wires.
The problem occurs as the lead truck touches the frog.
The locos stall if they are running on speed step 1, but they do not stall if running at speed step 3 or higher.
So, these are the symptoms that you report.
Mister Beasley raises the issue of stalls versus shorts, and you should confirm that the problem you are experiencing is, indeed, a stall and not a short. My guess is that it is a stall because shorts at the frog on Atlas turnouts are not common unless there is a fault with the wheel flanges on the locos. Also since you locos pass the frog without incident at speed step 3 or higher, it sounds like they are coasting through at those higher speeds, perhaps with a momentary loss of power, but not a short. But do Mister Beasley’s test to confirm this.
Let me ask you a series of questions, and then it would be helpful to all of us trying to help you to get specific answers to each question.
First, since the problem is limited to the straight through route, from which direction does the stall occur? From the short end of the turnout or from the long end of the turnout or both?
Second, does the stall occur only when the loco is running forward through the frog, or does the stall also occur when the loco is running in reverse through the frog? Does the problem occur
