On my current layout, I have unpowered Atlas Code 83 Custom Line #6 turnouts. I have no problems whatsoever with the unpowered frogs.
On my new layout, I am seriously considering Atlas Code 83 Custom Line #8 turnouts. Will I need to power the frogs to assure no loss of power as equipment crosses the longer frogs?
I suspect the frog is long enough in a 8 to nearly cover the full wheelbase of one truck of a 4 axle diesel or smaller. Of course if everything has keep alives in it, it wouldn;t matter, but soldering a wire to the frog is easier and cheaper than buying a whole lot of keep alives.
Yes, the Tortoise instruction sheet shows the wiring. You’d hook the frog wire to terminal 4, and your left and right rail feeds to 2 and 3. If it connects the wrong side to the frog, swap the wires on 2 and 3.
So, I guess that I am back to my original question. Do I really need to power the frog on an Atlas Code 83 Custom Line #8 turnout? Randy thinks not, and I kind of feel the same way. What do others think?
I am reluctant to buy a bunch of #8s if I am going to have to power the frogs.
No, I said you probably do - 4’s and 6’s I’ve not had a problem even with a relatively small loco, but the frog on the 8 is MUCH longer. If you have keep alives in all locos you probably don’t. That only applies to DCC. I’d still rather just power the frogs than use keep alives in every loco.
My suggestion is to take it one step at a time. Add the frog feeders to the turnouts before installing them but don’t do anything else until you have had a chance to run all your engines over the #8s. If you have a problem the feeders are already there to fix it. If you don’t have a problem all that has happened is that you spent a couple of extra minutes adding a wire.
I’m going to add a word of caution regarding the Atlas Customline Code 83 #8 turnouts based on my own experience with one of them. The #8 point rails are much different from the #6s. The #6 point rails are stamped nickel silver but the #8 point rails appear to be cast metal of some sort. I believe that the #8 point rails have a weak point where the tab that keeps the point rails on the throw bar is concerned. The tab is easily broken off of the point rail.
Here is how I discovered the problem. I bought a #8 to use as a test sample for the club’s new layout. The first thing I did was to tune the turnout so that everything would work correctly. While doing that I noticed that one of the point rails did not fit into the stock rail properly. It was twisted a bit, enough that the tip of the point rail was not parallel to the indent in the stock rail. It was sticking out enough at the top that I thought it might catch the wheel flanges. When I tried to gently twist the tip of the point rail into place the tab that holds the point rail on the throw bar broke off. I wasn’t applying much force at all. I was surprised at how easily it broke.
If you decide to use the #8s I would suggest that, if you need to adjust a point rail, remove the point rail from the turnout completely so that you can bend it without putting any stress on the throwbar tab, and definitely do not attempt to bend the tab even slightly.
That’s my experience with one single Atlas Customline Code 83 #8 turnout. Maybe the turnout point rail was defective, or maybe I am more ham fisted that I think I am, but the bottom line for me was that I strongly recommended that the club not use them, which they did not.
I will add one other observation about the #8s. I tried to solder the tab back on but I couldn’t get the solder to stick to the cast point rail despite several attempts (please refrain from offering me any tips on how to solder. I know how to solder). If you plan
Mine is in a 24’ x 40’ room above my detached garage, and I have #8’s for lots of my mainline crossovers.
I know lots of people with larger layouts than mine…
But it is not just about how much space you have, but how you choose to use it. While large, my layout is relatively simple with broad curves and large turnouts.
You may well be right Sheldon, but even if I had a dud the design of the #8s is questionable IMHO. Why use very thin point rail castings when there would be fewer potential complications if they used stamped points?
If the #6s had been constructed the same way as the #8s, the club would be using Peco turnouts.
