Atlas Code 83 Super Switch Users
I am considering using Atlas Code 83 Super Switches with my new layout. I will be using 1/4 lauan plywood for the roadbed on top of 3/4" birch plywood. The Atlas web site strongly encourages users of the Atlas Code 83 # 6 Super Switches to use the Atlas Snap Relay to power the frog. The engines that I will be using on this layout are an Athearn SW 1500 and a Kato NW2. Am I going to have a problem with these Atlas Code 83 Super Switches if I do not power the frog with the Atlas Snap Relay. I am new to the hobby and I can use a lot of expertise in dealing this issue. Please help this “newbie” with the advice of those who have used the Atlas Code 83 # 6 Super Switches.
As long as you’re not going to be running short-wheelbase (i.e. 0-4-0, trackmobiles, or 4-wheel Plymouth-type switchers), you should be fine, as long as the locomotives pick up power from all wheels. Our club mostly uses Peco turnouts, but there was one spot where a C83 Super fit the radius of a curve perfectly, and it’s been in place for about 8 years now with no problems.
One word of advice, though…there are two small plates under the rails to make electrical contact from the outside rails to the point rails. You will want to solder them in order to keep the contacts from eventually breaking loose from the rails.
Good luck!
[#ditto] I would recommend adding the wire to the frog and letting it hang under the layout though. It’s easier to attach the wire from the bottom of the turnout before you lay it in place. It’s a pain once the turnout is laid. You never know if you’ll want to power your frogs some time in the future.
Don’t you mean Atlas Code 83 Super “Turnout” Users?
ATLAS code 83 switches are mechanical’ devices. They do not know what switch machine are attached.
If you want to ‘power’ your frogs I think RIX or TORTOISE switch machines would would be preferable. Either/Or (don’t mix). These both come with extra electrical contacts, to do so.
If your ‘SUPER SWITCHES’ come with switch machines, I’d buy them without, and feed them with under-table Tortoises’ and DIODES to run off of AC.
