Does anyone have any problems running an Atlas GP38 over a peco code 100 dbl slip?
I have a few trains on my layout (Bachmann, Athern) none of them seem to have any trouble getting through but when I try to go over it with this Atlas it seems to be getting caught on guide rail right at the"V" of the frog. Are these wheel sets slightly thicker than the others or do you think there is something more sinister going on?
Any thoughts or suggestions
I have checked the track and wheel sets and they are in gauge !
The most common problem with Peco code 100 and also some of their code 75 is the flange way gaps being too wide. I do not have any double slips but I have many code 100 turnouts on my portable modules. Just about all of them have a .015 styrene shim glued to the guard rails to close the gap and keep the opposite wheel from picking the frog point. Peco builds their non code 83 to the British standard of flange way. Remember the old pizza cutter looking wheels? Their wheel flanges are still wider than the NMRA standard.
Another possibility is the truck swing of the GP38. Make sure the trucks swivel and try to eliminate any S curves going through the slip.
We have three Peco code 100 double-slip switches on our HO scale club layout and no locomotive has ever had a problem going through them. I think the wheels on the locomotive might be out of gauge.
