Atlas GP40 repainting
Well, I did it again- I bought another locomotive to be stripped of factory paint, and redone into a Wheeling and Lake Erie locomotive-kind of. It’s going to be repainted into Wheeling 303, an ex-Rio Grande GP40 still in Rio Grande colors. So, my question is: Who has removed the paint off Atlas products, is it required to do so, and what is the best product to use to remove said paint, if needed?
I’ll post a photo of it when it’s done/
The best paint remover I’ve found is Denatured Alcohol, it doesn’t disturb the plastic. A small plastic brush or toothbrush works very good.
Any Big Box stores sell Denatured Alcohol.
Mel
My Model Railroad
Bakersfield, California
91% rubbing alcohol will also strip paint with damage to the plastic body. Most drug stores and some groceries carry it. Using a toothbrush is a great suggestion.
I hope you meant “without”.
Hummm, my “out” fell out. Thanks!
Denatured alcohol contains methanol which is readily absorbed from vapor or skin contact. Wear gloves, don’t use it indoors it does bad stuff to your vision and brain.
In full disclosure I was just stripping a gondola with denatured alcohol and I wondered why it was so pungent. That started me looking into what makes it denatured.
Used the 91% stuff. It did the trick.
