My Atlas HH660 with DCC sound, which has about two hours run time on it, has started dieing when it starts around a curve. I pulled the shell and all the wiring looks good and then I looked at the trucks. It appears the side frames and metal wheel wipers are just enough wider than the wheels so that on a curve the wheels on the outside of the curve pull away from the wipers. I laid the frame on its side and using my volt/ohm meter applied a very slight pressure to the wheels on the side of the same truck and also on the same side forward and back truck wheels and electrical contact is lost. The wheels are in gauge using my trustie NMRA gauge. Could the truck side frames and wipers have spread just enough to lose contact, is this a common problem, and what is the solution? Thanks for any suggestions.
Capt. Brigg Franklin CEO
Pacific Cascade Railway in HO Gauge
Route of the Northern Star
