I’ve got a recently-released Atlas GP38 that is giving me dcc problems.
I’ve read other threads (usually regarding Bachmann) about capacitors on the light board that interfere with proper dcc operation. I’m wondering if that’s the case here.
Some background: I received the loco about 10 days ago. This was the “DC, dcc ready” version and I had read that it came with an 8-pin connector. OK, I have a few spare 8-pin decoders (Digitrax, TCS).
It ran ok out-of-the-box on a short test track using DC.
I took the shell off, and found there was not only an 8 pin connector on the board, but a 21 pin as well, with what looked to be a “dummy plug” plugged into it.
I pulled off the 21 pin dummy connector, and tried a TCS 8 pin decoder. The engine ran and I should have left it that way, but the headlights were giving me problems. Time to try another decoder.
Swapped it out for a digitrax DH166 or 126. Now… doesn’t run.
I’m using a Roco z21 running on a Samsung tablet, so went to the programming pane and tried some basic commands. I was getting an error message to wit: “command could not be entered, decoder failed to respond”. I don’t recall ever seeing that error before (and I have at least 25 other locos).
Hmmmm… maybe the 21 pin dummy plug is supposed to remain in place? I put it back and… POOF! Smoke from the 8 pin decoder. Nope, that’s not it. [:O]
So I took off the 21 pin dummy again, and re-connected the TCS decoder – and now, it won’t work, either.
In fact, none of the other four 8-pin decoders I have would run the engine. The lights would activate, but the loco wouldn’t run.
So… I ordered an ESU LokPilot 5 21-pin decoder. I have older ESU decoders in three other locos and they work very well.
Put the LokPilot 5 on the 21-pin connector and the engine runs and lights work. BUT… it doesn&
