It had been a few years since I bought some of these freight cars. My impression was that they were decent cars.
I just got one of the Evans 53’ cars. When I put it on the track it wanted to wobble side to side for a bit before stopping. I took it off to tighten the trucks and was surprised to find that the trucks were a press fit without screws. I looked at some of the other Master Line cars that I have and found that some are made the same way while others have screws. None of those cars wobble so I hadn’t noticed this before.
That leads to two questions:
how do you stop the wobble with the press fit?
how can you tell which method is used before buying them?
Worse than the pins on the trucks are the glued-shut draft gear boxes.
Leave the trucks, change the wheels.
I anticipate the fact that the cars will require some work before they can be “layout-worthy”. That means removing the molded Atlas draft gear and truck king pins. Pry off the existing draft gear and replace with a Kadee snap-fit draft gear. I plug the oversized hole with styrene, file it flat and tap it for a 2-56 screw.
I recall buying a bunch of the Atlas wood reefers and was sorely disappointed with their use of toy-like trucks under an otherwise nice model.
Beats me…but I’d simply replace the press-in plastic pins with suitably-sized screws…applied carefully, the screws will cut their own threads in the car’s underbody, allowing you to tighten or loosen them as needed.
I was going by your statement that the car wobbles.
Anytime I’ve had a wobbling car the cause was a wheelset with either an out-of-round wheel, poorly formed axle insulator or, rarely, a bent axle.
My response to that is that you can remove the existing wheelsets, perhaps spin a “truck tuner” in the recess for the axle ends and fit replacement wheelsets WITHOUT removing the trucks themselves from the car, assuming you didn’t want to break the pins (some are glued in on Atlas cars) by removing the trucks.
If you mean the car doesn’t sit firmly on the bolsters then you should remove the trucks and look for flash on the seat of the car bolster. Many manufacturers provide a nib or post on either side of the bolster pin on one end of the car and sometimes a way for the truck to pivot axially on the other end.
I guess wobble is the wrong word. While it is not moving the car rocks from side to side before settling down.
As to replacing the pin with a screw, I don’t have a problem with that as long as I don’t do damage removing the truck. Do they just pull off the pin/post?
Turn car upside down and check how much the truck flops from side to side.
Sometimes the post is too long and the pin/screw head bottoms on the end of the post before contacting the truck bolster. If this is the case you may need to file down the end of the post a bit.
Well,you said there was a pin. I said pin/screw. Maybe I should have said pin OR screw. Regardless, the principal is the same. The head of the screw keeps the truck from falling off the car. The head of the pin does the same thing.
In either case when you remove the pin or screw, and with the truck still on the car, see if the post on the car sticks up above the surface of the hole in the truck bolster. If it does, then if you tighten the screw all the way, or push the pin down into the post hole until the pin head contacts the top of the post, you will end up with slop between the truck and the car. And this slop can result in the car flopping to one or the other side.
This is a picture of how the trucks are pinned in place.
Here is a closeup:
What I am hoping to get from the group is guidance on how the truck is pinned. Is this a press fit or is it glued in? I don’t want to damage it by not knowing what I am dealing with.
It’s been over a decade but I believe the pins are split on the other side of the underframe. A wiggle and gentle pull should release it. You could also remove the floor and push the pins out from the top side.
I suspect that the pins are just a press fit. If so, the trucks should pop off without too much effort. If they won’t pop off, try using a small flat bladed screwdriver to gently pry them off. If that doesn’t work, then you could try drilling the pins out making sure to start the drill exactly on the center of the pin. I would start with a small pilot drill.
Once the trucks are off you can replace the pins with 2-56 screws. Depending on the size of the pin shank, you might have to fill the hole in the bolster with styrene tube and then drill/tap a suitably sized hole in the styrene tube.
As was mentioned, the height of the screw post above the bolster is important. If the post is too tall, the screw will hit the top of the post before coming in contact with the truck and the truck will likely still wobble. If that happens, gently file down the post a bit at a time until the truck can be screwed down until it doesn’t move. Then back the screw off just enough so that the truck can rotate smoothly without wobbling.
Some people, myself included, suggest that one truck should not wobble but that the other truck should have a bit of wobble in it. The theory is that the trucks/car can follow slightly uneven track without lifting a wheel off and possibly derailing.
Maybe take the correct size nylon washer or two and cut a slit similar to a lock washer. Then work it around the head of the press pin to take up the slack, of course not to tight.
…Nevermind, after seeing the picture late, that obviously won’t work.
Rick’s Pic
Hard to tell what your situation is with those press pins from a picture but had an N scale car where the trucks would not come off. They had glued or permanent pressed pins that looked almost exactly like that.
If they don’t come out, start with a micro drill bit dead center and graduate up bits carfully drilling shallow, (piece of tape wrapped several times around the drill bit as a stop) until the truck is free. Then carefully file the shank of the press pin flush to the collar it’s in. Then graduate bits up again, (ending at the correct size hole for the ideal sized screw), adjusted well like Wayne suggested.
Certainly works as I’ve done the procedure with great success.
The Atlas Evans boxcar was probably the first Master Line series cars tooled for China production. Its decades old. I have several of these and the newer runs also have the pin.
I don’t think any other Atlas Master car has them. The old Kaolin tank cars do but they are even older than the Evans boxcar and I don’t think Atlas makes them anymore.
I have several of these boxcars with the pin and none of mine wobble on the track. They are very stable on the trucks.
Is the pin pushed in far enough?
Have you tried the Kadee red fiber washer on the truck mount? If the hole is too smal ream it out with a small file. Those fiber washers always solved truck wobble for me.
If not, screw might work, but generally wobble is due to too much space in between the truck bolster and the truck mount, so screwing it down tighter isn’t going to close up that space. Its why I find that a Kadee washer usually works.
Everything Atlas makes is press fit. Its meant to be taken out and put back in. I’ve never removed the trucks on my Atlas Evans boxcars, but I assume they are designed to just come out when you pull the trucks away from the car. Thats what I would try. Being careful to position your fingers and support the car floor correctly of course.
Ok, I just flipped one of mine over and removed the pins. When I pulled one truck, the entire underframe including coupler boxes separated from the black floor. The underframe is one press-fit piece containing all of the brake rigging, the top of the coupler boxes, and the truck mounts. (The two big beams running along the center of the car containing the truck mounts and the perpendicular ribs extending to the car sides)
I flipped the underframe and remove the pins by pulling on the truck (Could have done this before if I had better secured the frame to the bottom of the car). Careful, the first one I removed went flying because its a tight press-fit, but I found it. So be prepared.
Then I just reassembled by replacing the trucks and inserting the pin, pressing it into the truck mounts from the bottom with a small screwdriver, and re-press fitting the long underframe back into the bottom of the car.
No glue anywhere. Its a legacy design, but it works fine, IMO.
