I have a couple of ho Atlas S2’s with a flickering headlight problem. The light that is supposed to be off when the loco is moving flickers. I have cleaned the track and the wheels on the locos and no change. What else needs to be done and is there a youtube video that might help? thanks in advance
Diodes have to be installed pointing in the right direction. The arrow in the diode symbol points in the direction of the desired current flow. Rather than spending hours trying to figure out the proper current flow, just hook the diode up temporarily until you get the right setup.
The squiggly line represents a 1000 ohm resistor. Without a resistor you will fry the LED. There may be one in the circuit already, but if you add in a second resistor it won’t affect the light. Resistors are not polarity sensitive, nor does it matter which side of the LED they are on.
