Atlas N Scale Silver Series - High Speed on PWM?
Hi all,
I’m building a coffee table layout in N scale, and I’ve got a PWM throttle for it and a few DC locomotives. Most of the locomotives (Bachmann and Tomix) work okay. However, it’s a different story for the Atlas silver series Alco S-4.
When testing, I found that this locomotive would just sit on the track until about halfway through the throttle, then it would take off at close to full speed. Further experimentation found that there was a very narrow area of the throttle knob rotation where it would run at a reasonable speed. But after this, it would just run off at close to full speed.
Another thing I noticed is that the other locomotives made a high-pitched whine before moving, and this dropped off as the speed increased. The S-4 didn’t make any noise at all.
Given the above, I suspect that something on the circuit board of the S-4 is interfering with the pulse width modulation performance. Is there anything I can do to fix this?
PWM is basically only noticably effective at low loads / speeds … as the throttle gets turned up the PWM is less of a factor, until at wide open throttle the PWM component is not functional at all …
It sounds like it might have a dual-mode DCC decoder installed.
These will work (poorly) on DC, but PWM DC can really mess with them.
I think this is what the standard DC board looks like.
That is my best idea.
I do not miss the days of trying to teach people that 100% duty cycle PWM is the same as filtered DC.
My life is much easier now.
-Kevin
Agreed, sure sounds like a decoder. They hate PWM DC.
I have removed lots of pesky decoders in the last 20 years or so.
I have not found a dual mode decoder yet that will run on the high frequency PWM of my Aristo Train Engineer throttles.
Sheldon
I’ve checked, and the model is listed as ‘DC, DCC ready’. It was also priced like a non-DCC locomotive.
OK, the other thing to check for is capacitors on the motor leads - they can mess with PWM throttles as well.
Sheldon
