Does anybody have any experience using Caboose Ind. 206s ground throws with the Atlas Custom turnouts? I looked at the ground throws and the pin sticking down looks like its too big for the hole in the turnout I have used these on the regular Altas turnouts , I had to drill the hole a bit bigger , but the bar on the custom turnout looks like its too thin to allow me to drill to the proper size,
I use them. The pin is too large, especially for the code 55 turnouts. I just use a pin vice and a small drill bi to open up the hold in the turnout. They work GREAT. easty to install, and reliable. One trick I use is to paint the handle of the throws, green for the side that is up when the switch is aligned for the mainline and red for when it aligned for the diverging track. This way you do not have to guess which way he switch is thrown when you approach it.
Hey thanks for the info. Yesterday i bought some Altas custom line turmouts and found the correct drill bit and presto working ground throw i like the idea about the colors , good thought
