I am having trouble getting the Atlas Quantum Engineer controller to work. When any of the buttons on the controller are pressed (e.g. horn, bell, status report, etc.), the contoller makes clicking sounds, as it should, but the engine does not perform the function. Sometimes it will cause the engine to competely stop as if the throttle was turned off but almost immediately the engine will come back online making the escaping air sound. The engine does make sound, increasing with throttle position and the horn will sound if using the direction switch on the power source. I have reset the engine as instructed in the trouble shooting section of the manual but no change in symptoms. I tried another engine, thinking the trouble was with the engine, but again, the same symptoms. Both engines are Atlas, one an SD-35, the other, a GP-40.
Thinking now that the trouble must be with the controller, I swapped it out with a different controller, but again, no change in symptoms. Everything remained exactly the same right down the line. However, the second controller has the Broadway Limited logo instead of the Atlas logo. From other discussions on the forum, it would appear they are the same box with a different logo.
Any ideas on what might be the trouble?
